Bonnet issue 365/GT4 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by SouthWestFerrari, Aug 12, 2025.
  1. SouthWestFerrari
    Sep 10, 2024
    1
    Andreas Adamou
    Hi folks,
    Got an issue with a Ferrari 365/GT4 2+2 The bonnet struts were weak and allowed the bonnet to slam shut, now we cannot open the bonnet even with the emergency pull. Has anyone encountered this sort of issue before, Please only respond if you have encountered this problem as we have tried all options so far. Maybe one of the Ferrari bodyshops can recommend a procedure! Grateful for any sound advice.
    Regards
    Andreas.
  2. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,890
    Switzerland
    Simon
    Moved to the model dedicated forum, I am sure you will get the support you need here.
  3. Zanny1
    Zanny1 Formula 3
    1,158
    Arizona
    On my 365 GTC/4..... had the right side cable break, which the emergency cable does not operate. After fishing around with bent coat-hanger, I managed to get the right side latch to pop and replaced the cable. Your car may be different.
    Suggest you gently pull the left side up and try the release handle. if it pops free, then go to the right side and repeat.
    I adjust the bumpers up enough to place some compression against the hood. I NEVER drop the hood to latch it. I set the hood down and gently push each corner where the latch is until the latch closes. It takes some fiddling to get the latch in this position.
    Any changes made to one side will affect the other.... so it's trial and error to get them right.
    PM me if you wish to talk about this. The latches are very difficult to reach from the underside of the car.
    Ak Jim likes this.
  4. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,736
    Argent/Brasil
    Guido
    You can try ...1 person pulling the emergency pull and an other person pressing the hood down with force just above the latches.
  5. Ak Jim
    Ak Jim F1 Veteran
    9,745
    North Pole AK
    This was my thoughts. Might need three people. One to pull release and one on each back corner of the hood pushing down or even rapidly pushing down and releasing pressure as the release is pulled.
