Boot lid lock for 246 L series | FerrariChat
Discussion in '206/246' started by pshoejberg, Nov 21, 2013.
  1. pshoejberg
    pshoejberg Formula 3
    1,844
    Denmark
    Peter H
    #1 pshoejberg, Nov 21, 2013
    Hi all,
    I'm again in great need of help from you L-series owners or other experts on the locking system. I'm preparing my boot lid lock for chroming but are unsure whether the lock is complete. The lock hole was blinded off with a simple chrome cap when I acquired the car, but I found what I believe is the original lock (Or part of it?) in a box of spares that followed the car. I hope that someone can confirm if something is missing and maybe supply a picture.
    Peter
  2. sranderson
    sranderson Formula Junior
    Nov 15, 2003
    286
    SRA
    Hi Peter,
    If you don't get a reply from someone tonight, I'll take a pics of mine tomorrow.
    Steve
    00988
  3. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    #3 dgt, Nov 22, 2013
    Peter,
    The lock you found looks correct (does the door key fit?), see attached photo of it disassembled.
    However, your trunk locking mechanism has been modified/replaced, that whole mess in the 4th and 5th photo is wrong. Your striker support was cut out and that metal strap below added to support a cable release mechanism which not correct for L-series.
    Originally, there was a latch (P/N 20.26.01) mounted under the trunk lid with a striker (P/N 20.26.10) on the trunk itself. See the last photo below.
    You can try McCann for the latch. I think you have some welding to do...
    Andrew
  4. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    #4 dgt, Nov 23, 2013
  5. pshoejberg
    1,844
    Denmark
    Peter H
    #5 pshoejberg, Nov 23, 2013
    Thank you very much gentlemen!
    Your input is much appreciated and unfortunately confirm my concerns regarding missing parts though not on the key lock assembly itself.
    I have no reasons to believe that the key lock is anything but original. It looks like someone mistreated it in attempt to open it with a screwdriver. Eventually it was removed and the locking mechanism was "rebuild".
    I took the key lock apart and found it dead dry with all locking pins stuck, so maybe that explains the screwdriver violence.
    I'm now on the lookout for the original striker and the latch mechanism. If anyone should be so fortunate to have these parts laying around please don't hesitate to let me know (I am still also missing an air box lid early type 206). Alternatively I will have to make the parts myself and for that it will be nice with a few more pictures from different angles.
    The weekend is spend in my workshop dismantling the suspension system.........Pure enjoyment and thanks god all non wear parts in remarkeble good condition.
    Have a nice weekend and good wrenching.
    Peter
  6. pshoejberg
    1,844
    Denmark
    Peter H
    Thanks for the hint Andrew....One NOS latch is heading my way from Dennis McCann; I guess that was a lucky punch! The striker I will have to fabricate myself from your pictures and the latch itself.
    Peter
  7. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I knew he had it … :)
  8. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
  9. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    thanks Simon, but this one seems to be a different one (much longer)
    if anybody has a correct one please let us know
    regards Matthias
  10. pshoejberg
    1,844
    Denmark
    Peter H
    #10 pshoejberg, Jan 5, 2014
    I received the latch from Dennis just before Christmas. A pieces of folded sheet metal with a spring and a cast'ed locking bar of aluminum....The quality is just as you would expect it from a "cheap" Ferrari of that era....-:)
    I spent my weekend fabricating the striker as per photos from Andrew and it turned out great (I might change opinion when I have to adjust the boot lid in the future). I also made a choke cable holder based on the drawing from the official parts diagram....I wonder if anyone can tell me if I'm close to the real deal...
    Both parts goes to plating next week and then I'm a little step closer to having my "nice to have" spare parts list covered.
    Have a nice weekend
    Peter
  11. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,335
    Iain
    #11 isuk, Jan 5, 2014
  12. pshoejberg
    1,844
    Denmark
    Peter H
    Maybe......but on the other hand there are so many parts that's not the same between the early L series and the rest of the 246 series....Hopefully an L-series owner can chime in.
    Peter
  13. pshoejberg
    1,844
    Denmark
    Peter H
    #13 pshoejberg, Jan 5, 2014
    I have just prepared the bracket for an E type choke cable support to be on the safe side.....I will wait with the soldering process until I know if it's the correct bracket for the L series....
  14. pshoejberg
    1,844
    Denmark
    Peter H
    #14 pshoejberg, Jan 13, 2014
  15. afer
    afer Karting
    Jun 4, 2009
    122
    Uruguay, S. America
    Alvaro Ferraro
    #15 afer, Jan 13, 2014
    Hello Isuk. I was looking at the pictures before start the restoration and the part look different in my L series. I don't have now the pictures with the part zinc plated in the engine after the resto. But I can take new ones when I return to Montevideo at the end of this month, if you need them. Regards, Alvaro
  16. pshoejberg
    1,844
    Denmark
    Peter H
    Thanks for the response Alvaro. I would be very interested in seeing some more detailed pictures of your choke cable bracket when you get access to your car. It looks like this type of bracket will fit my caburator setup perfectly.
    Regards Peter
  17. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #17 GermanDino, Jan 13, 2014
    Peter, here is a picture of this engine side of #01100 pre restoration....
    any help?
  18. pshoejberg
    1,844
    Denmark
    Peter H
    Great help thanks...I now have what I need to make a L series repro bracket...
    Peter
  19. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    nice earth strap too :)
  20. pshoejberg
    1,844
    Denmark
    Peter H
    #20 pshoejberg, Apr 11, 2014
    Third time lucky....I have now been able to fabricate the correct choker cable bracket thanks to all the excellent input from the FC society.
    Peter
