Bora Brakes | FerrariChat
Bora Brakes
Discussion in 'Maserati' started by sunburn, Apr 8, 2006.
  1. sunburn
    sunburn Formula Junior
    Nov 2, 2003
    694
    Dawsonville, GA
    Rick R.
    I just had some new wheels built for my '74 Bora and when I removed the
    old ones I noticed a small leak from the passenger side front caliper.
    It looks like it coming from one of the pistons as the lines and
    fittings are dry. Are there any Girling (or any ) rebuild kits out
    there? Is there anything special about rebuilding these calipers? I
    have done other (normal) calipers in the past with no problems.
    Thanks,
    Rick . . . .
  2. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    8,987
    Rick,
    contact me privately: [email protected]
    Thanks.
    Ciao!
    Walter
  3. staatsof
    95,948
    Fuggetaboutitland
    Bob
    Rick,
    If you get the correct kit it's not a problem. But and this is a big but, please remember that this is a system that utilizes LHM not brake fluid so the rubber must be different. Typically, there's no corrosion in these systems because the LHM fluid does not absorb water as readily as brake fluid but check it out first. Yes there is a Girling kit for the fronts as well as the rears and no there's nothing special about the rebuild. It has dust boots and square cut rubber O-rings.
    Bob S.
