Boring little SuperAmerica Roof Question | FerrariChat
Discussion in '456/550/575' started by Sir Paul, Dec 10, 2017.
  1. Sir Paul
    Sir Paul Formula Junior
    Feb 22, 2008
    537
    HONG KONG
    Hi folks.
    Long time no write. I trust you are all well.
    My SA is running fine, in fact very well at 12 years old and 18K miles, except the constant fiddling with the tire pressures to keep the sensors happy!
    No real roof problems. Opens/closes OK. Struts OK at the moment and no delamination.
    However, I am getting a bit of curious curling of the rubber between the top glass and the rear glass.
    Any ideas on the best way to "stick" it back down properly and the right adhesive to use?
    Here are a couple of pics.
    PAUL
  2. jznd
    jznd Formula Junior
    Oct 26, 2008
    373
    Hong Kong
    Have a similar though less pronounced situation on my 550, interior side of the windows, the rubber strip is also popping up a bit from the leather underneath. Curious if there's a solution as well.
  3. tazandjan
    39,182
    Paul- It actually looks like the center part of the "T" seal has popped out of its channel in a couple of places. Have you tried to seat it with a plastic trim tool or piece of wood? Does not look like it will glue down without being seated first.
  4. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,660
    Palo Alto,CA,USA
    Walt Kimball
    If glue is called for,Permatex Weatherstrip Cement #80328.
  5. Sir Paul
    Feb 22, 2008
    537
    HONG KONG
    Thanks Guys.
    Much appreciated.
    Good tip Terry. I tried pushing it down but did not seem to have the feel of there being a channel to pop into but will take another look with a tool.
    After that I guess things get a bit more sticky!:)
    Thanks again. both.
    Regards
    PAUL
