BOSCH 0280160525 512TR/M | FerrariChat
Discussion in 'Boxers/TR/M' started by HOU, Oct 18, 2012.
  1. HOU
    HOU Karting
    May 2, 2009
    90
    Houston, Texas
    John S
    subject fuel pressure regulator is getting hard to find and expensive. do you think that regulator on other 1995 motronic ferraris will work ?
    that part number is 0280160564
  2. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Would you consider purchasing an adjustable fuel regulator & adding the appropriate fittings? Lower cost and you can dial in the pressue.
    f355al likes this.
  3. Steve Magnusson
    26,826
    The www.allferrariparts.com database says Bosch 0280160564 = F PN 167321 (which the F parts book shows is used on 512TR/M). Are you getting that Bosch 0280160525 part number off your old parts or from some other reference?
    www.rockauto.com has the Standard Motor Products brand equivalent PR301 for ~$94 -- does your old part look like the photo they have?
  4. HOU
    HOU Karting
    May 2, 2009
    90
    Houston, Texas
    John S
    my fuel pressure regulators are stamped Bosch 0280160525. i think bosch must have superceded them with the ..........564.
    my engine stopped running rich (black exhaust) on 1/6 when i carefully removed, cleaned, blew out the vacuum sensing lines, and SWITCHED both regulators to the other side.
    my engine is running great now but i am preparing for eventual failure of the regulators which seem to be a very common occurence. (not unexpected in a 17 year old car, probably not designed for current gasoline chemistry)
  5. HOU
    HOU Karting
    May 2, 2009
    90
    Houston, Texas
    John S
    the picture of the STANDARD MOTOR PRODUCT PR301 does look like my regulator.
    i will probably invest in one and try it.
    thanks for the lead
  6. HOU
    HOU Karting
    May 2, 2009
    90
    Houston, Texas
    John S
    STANDARD AUTO PARTS PR301 works and no problems after 35 miles. the box says made in usa.
  7. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,426
    ky
    Adam
    Reviving this thread. Any lead source for a regulator? I can't seem to find one?
    f355al likes this.
  8. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    I searched for the standard PR301 and can't find that part anywhere. Is there another brand?
  9. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,541
    romano schwabel
    what part number you need?
    0280160525 or 0280160564
  10. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    I am not sure of the part number but it's the fuel pressure regulator that I think is 3.8 bar of pressure that fits on the rail for the 512TR. I see some crazy prices online for used ones.
  11. turbo-joe
    Apr 6, 2008
    9,541
    romano schwabel
    part number would be great to find, because the 3.8 bar is not stamped on the reguators
  12. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    I believe it's the BOSCH # 0280160564
    f355al likes this.
