Bosch Coil Pack | FerrariChat
Bosch Coil Pack
Discussion in '348/355' started by Gary Logan, May 11, 2013.
  1. Gary Logan
    Gary Logan Karting
    Dec 19, 2009
    54
    West Vancouver, BC
    Gary Logan
    Gents: Trying to nail down slight intermittant miss on my 97 355. In case I have to replace a coil pack, Bosch #138255, any cross-reference numbers floating around or other vehicle makes that use this coil.
    Gary
  2. MitchG
    MitchG Karting
    Feb 13, 2011
    68
    Central Illinois USA
    Mitch Griffin
    That list also includes Land Rover Discovery.... if that is a replacement they are cheap and available.
  3. Gary Logan
    Gary Logan Karting
    Dec 19, 2009
    54
    West Vancouver, BC
    Gary Logan
    Gents: Thanks for the reply, will check it out this week.
  4. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    465
    London
    Steve C
    To give you an idea of pricing, I just bought two coil packs over here in the UK for £56, which is less than $90. My car developed a slight misfire accompanied by a slow down light caused by unburnt fuel hitting the cat. I got it home using the cat bypass override fitted by the previous owner. I have no spark from lower-right coil of LH coil pack, but thought I may as well replace both packs while I'm at it as the other one is bound to be on the way out too.
  5. vincentf355
    vincentf355 Karting
    Feb 24, 2010
    122
    Taipei
    vincent tseng
    Mine on 97 355 have been replaced recently. It is Bosch 0221503407 which could be found on amazon and cheap.
  6. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Not sure if this is in the cross reference parts sticky yet... If not it should be.
    Thanks for the information
  7. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ...... :)
