Bosch ignition coil | FerrariChat
Bosch ignition coil
Discussion in 'Maserati' started by vlasic ludovic, Aug 13, 2018.
  1. vlasic ludovic
    vlasic ludovic Karting
    Apr 13, 2015
    60
    Nice France
    Vlasic ludovic
    Hi all,
    according to maserati manual for early V8, like indy and ghibli, the ignition coil is a bosch B221 040 003.
    but, did you know a cross reference for new one ? This ignition coil should be compatible with points.
    Thanks for your help, or idea .
    Ludovic
  2. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Ludo, All,
    I've got the info that these coils were very specific, and are considered as Competition coils.
    2 Bosch Specialists I know in Germany and the Netherlands even never did hear about these !
    Absolutely no real substitute/replacement/cross ref.
    Only a recommended adaptation : Bosch 0 221 121 001.
    And only in old versions.
    Above all no modern Brazilain made coild w/ alloy / grey body.
    Alfa Montreals originally used 2 x 0 221 121 002 coils.
    As an alternative, you also could use Beru ZS-109.
  3. red27
    red27 Formula Junior
    Sep 7, 2010
    925
    London UK
    Mark Oliver
  4. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Mark,
    As you can see, they do not speak about the coil ref. B ....
    They even do not speak about Ghibli SS at all.
    The red coil on the right is :
    - to be used with ballast ONLY, and not electronic ignition compatible,
    - made in Brazil and nobody serious will advise it.
    Best,
  5. red27
    Sep 7, 2010
    925
    London UK
    Mark Oliver
    Interesting. I wonder what Mercedes recommend for the 6.3/6.9 M100 V8 engine with the same dual points setup.
  6. vlasic ludovic
    Apr 13, 2015
    60
    Nice France
    Vlasic ludovic
    Very interesting , did you know if BERU 109 should be mount with the ballast resistor ?
    I have already hear that bosch (made in brazil) are not serious coil .....
  7. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Absolutely NO ballast w/ coils running that kind a ECU/CDI.
  8. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    If its run with the Bosch CDI its not a coil its a single wind amplifier, Porsche also used them with the 70s 911
  9. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    No coil ?
  10. Froggie
    Froggie Formula Junior
    Sep 27, 2017
    534
    Belgium
    Serge
  11. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    That's it !
  12. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Did you experience any pb ? Even at high revs ?
    But do you still have the original Bosch CDI ?
    Have you still got the bendiw red top fuel pump(s) or modern Facet ?
  13. Froggie
    Sep 27, 2017
    534
    Belgium
    Serge
  14. vlasic ludovic
    Apr 13, 2015
    60
    Nice France
    Vlasic ludovic
    So that's it ....
    Well to know it !
  15. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    On my own, I'm waiting for my B221 040 003 coil to check improvements.
    Or not.
  16. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Got the B221... coil.
    Runs perfectly.
    Just in case, I also bought a compatible NOS Bosch coil for 911 RSR.
    The B221 coil is twice as much big that the RSR one.
    Now, we also fixed the Facet fuel pumps pb.
    And I had my Bosch original CDI restored and heavily upgraded un germany.
    With fuel pumps feeding well, better than new CDI, and the right coil, it's still another car.
    However not yet perfectly tuned.
    So, the car was the last 2 weeks at a Specialist's for the last carb... tune.
    Now it's ready.
    As soon as I get the car back home, will post pics, and impressions.
  17. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Here are the pics of the 2 coils in place thx to an additional BMW coil holder !!
    It's provisional only.
    Until I tested both of them on the bank.
    The largest one (below) is the B Competition original for SS.
    The littlest (above) the replacement one advised when we have not the original. Impossible to find.
    With the stroboscope, or tuning the carbs by the ear, we did not fid any difference.
  18. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Closer pic : Image Unavailable, Please Login
  19. Candide
    Candide Formula 3
    Apr 6, 2017
    1,484
    Monaco
    Finally, both of the coils tested and perfectly running and equals in results on the bank, at any regime.
    So, I choose to fit the original and huge Bosch Competition coil in its specific very large backet.
    The 911RS one will go into the rear trunk w/ a tool in 10mm, just in case. Image Unavailable, Please Login
    MrMark likes this.
