Bosch ME7.3.2 Boot Mode "need help!" | FerrariChat
Discussion in '360/430' started by louie23, Jan 20, 2012.
  1. louie23
    louie23 Karting
    Jan 11, 2012
    81
    Japan
    Louie
    Anybody here have experience putting the ECU's in boot mode. I just picked up the AlienTech KessV2 interface, but the instructions are very vague.
  2. louie23
    louie23 Karting
    Jan 11, 2012
    81
    Japan
    Louie
    #2 louie23, Jan 20, 2012
  3. eric355
    eric355 Formula 3
    1,226
    Toulouse (France)
    Eric DECOUX
    If you want to read the complete EEPROM content, for a reflash, the answer is yes.
  4. justinn
    justinn Karting
    Jan 5, 2011
    114
    Austin TX
    Justin
    you ~should be able to flash through OBD2 with the correct interface as the ECU's support it, but I have only ever seen it done via a bench flash.
    Justin
  5. louie23
    louie23 Karting
    Jan 11, 2012
    81
    Japan
    Louie
    Thanks for the help guys, I just got around to replying. Reading and Re-Flashing is best done on the bench, no doubt. I've actually gotten really good at it now. Flashing can be done on the car, but there is a Jumper process required. Not to difficult, but a bit of a pain.
    Advice is: If you have the tuned file handy, it is best to write it while the ECU is on the Bench.
  6. Living4life
    Living4life Formula Junior
    Jun 29, 2008
    263
    Super simple to flash through the OBD 2 port with the right tool. I made a jump wire in 10 seconds and just removed a relay behind the passenger seat. You have to flash BOTH ecu's so it does take maybe 5-10 minutes but that is it. They never need to come out.
    I will admit the tool for doing this is probably not very cheap but my tuner had one.
