Bosch Warm Up Regulator Rebuilder | FerrariChat
Discussion in 'Technical Q&A' started by speedmoore, Jan 25, 2006.
  1. speedmoore
    speedmoore Formula 3
    Apr 15, 2003
    1,541
    Austin, Texas
    D Moore
    Can anyone help me with company that rebuilds WURs? I have a stack of them and would like to have a few rebuilt. Seems they just need a new bimetalic strip and spring. Anyone know of "kits" available to do them in house?
    d
  2. robertinOK
    robertinOK Karting
    Dec 5, 2003
    209
    Stillwater, Oklahoma
    RobertWakeling.com
    Hi,
    I rebuilt both regulators on my Boxer myself, it is a fairly trivial job if you're patient. Nothing needed replacment, (ie nothing was broken) but both were way out of spec. I purchased a fuel pressure gauge, and it's simply a case of shimming and/or adjusting the bimetalic strip operating point to acchieve the hot and cold running pressures. Just takes a little patience. The cost of the fuel pressure guage is easily offset by being able to do it yourself...and you'll know it's spot on.
    Robert
  3. LarryS
    LarryS Formula Junior
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
  4. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    John at SpecialTauto is the WUR go to guy. I had a good conversation with him last year when one of mine had a problem. Just don't get him started on Deloreans as he'll chew your ear off :)
  5. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    Patrick at BMA Auto Parts (http://www.bmaparts.com/) said:
    0 438 140 132 - $196.00 each Remanufactured.
    Turn around is usually a couple of days.
    I have worked with them and they are great.
    Mark
  6. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    The Porsche guys have been playing with these things a long time. They are very simple inside and usually the pressure is wrong. There is an aluminium plug that controls the response. You can remove the bottom and push the plug back a bit or it's easy to drill and tap and then use a bolt to move the plug up or down. You should use a meter to check continuity of the coil that heats the bi-metallic strip. YMMV
    Jeff Pintler
    89 348tb, 86 TR
  7. Shark49
    Shark49 Formula Junior
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    I need a new plug that goes into my WUR of my MOndial 3.2......
  8. speedmoore
    Apr 15, 2003
    1,541
    Austin, Texas
    D Moore
    Jeff,
    That part is easy as long as the "range" of pressure is correct. As they get old, the band increases and thus you can't tune that out. The bimetalic strip wears out and causes the band to increase, that replacement is the hard part.
    Mark thanks for the link
    d
  9. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    You don't want to move the pin to try to fix anything but cold control pressure setting. To use this to adjust warm pressure setting will screw up the curve. To adjust it correctly you will have to machine special tools and know how to set it properly. Most of the porsche guys end up with mixed results and eventualy having thiers rebuilt by a pro. I am in the business of rebuilding the fuel distributors and I know how to do the warm up regulators also, but I am too busy to do them also. SpecialTauto is one of my distributors and I reccomend people get their warm up reg's from him. In the future I may start to do the WUR's, if you have more questions about the CIS and how to test it and fix it call me.
    Larry Fletcher
    CIS Flow Tech Llc.
    251-929-3771
  10. Shark49
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    I wanted to open this thread back up because my warm-up regulator on my mondial3.2 works fine. Sort of. The electrical connection is corroded and I cant find a replacement piece. Anyone know where I can find it?
  11. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    the plug or the socket?
    maybe these guys can source the part...but they are in australia:
    http://www.petroject.com.au/efi.html#4
    wonder if they can supply other parts for the wur's, since they also rebuild them.
    if you need the plug, it looks like this one...may work:
    http://www.autronic.com/page_files/connectors.htm
    there's a list of distributors on the autronic site. If you get some info, please post as I may need to find pins for the blue plug on the fuel distributor.
    a junkyard is always an options.
    the connector would have to be pretty badly rotted to not be cleanable...how bad are they?
  12. Shark49
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    Awesome! The connector on the second link looks like it. I have a bunch of emails in and will let you know the results. THANKS!
    -Nathan
  13. k-jet57colin
    k-jet57colin Rookie
    May 16, 2017
    2
    Hi,
    I know it's a very long time since this post, I have kits, springs, diaphragms, all the parts you need. But I am also looking for old WURs to rebuild and hold as stock for exchange. Is there anything we can do?
    Colin
    K-JET  SPECIALISTS - HOME
