BOUGHT AN ASTON INSTEAD! | Page 2 | FerrariChat
Discussion in 'British' started by GPM, Jan 29, 2023.
  1. GPM
    GPM Formula Junior
    Mar 26, 2015
    553
    Vancouver BC
    i looked at an '16 Vanquish, have you had any problems worth mentioning with yours?
  2. Geflackt
    Geflackt Karting
    136
    Eastern PA.
    Between May when I got the car until late December I put on almost 5k miles. Has been great but a few very minor issues:
    - Front transmission oil cooler hose clamp(or hose) loosened at the cooler fitting. Caused a few drips on the garage floor. I simply replaced the clamp and it's been dry. At first I thought I had spilled some oil when I did my oil change.
    - Electrical: We jammed too much stuff in the trunk on a trip and the trunk lid switch got confused. Took some fooling to get the trunk open but never had to force it. So we're just careful about how much we put in the trunk.
    - Electrical: Biggest issue is around the audio. There are times the screen will open and look like it's playing music(I use a very old iPhone as an iPod), but the speakers don't pop up and the amp doesn't turn on. I figured out that if the ignition is shut off and then turned back on between 9m30s and 10m0s, the amp may not wake up. I have to let the car go to sleep for about 10 minutes, then it all comes back fine. I may build a circuit where I can trigger a reset on CAN or MOST(the optical bus). We've already reverse engineered the CAN and MOST bus in this car, so I could offer a full customizable DSP to replace the amp and still allow speaker drivers(for all speakers, plus the motors for the dash speakers). But not worth it yet. I just try to avoid cycling ignition around that time period. My car is a very early serial number and used the 2nd Gen entertainment system. I could go to the 3rd gen but not worth the cost.
    Otherwise, it's mostly been cleaning up detailing things from previous owners. Has a little under 25k miles now.
    The later '14's and up should have better and more stable entertainment systems. Overall the car seems very stout and wants to be driven. It could be used carefully as a daily driver. Does fine even in the rain.
    Get one!
  3. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,859
    SoCal
    Edward
    No electrical issues with mine, mine is a 14. Pretty bullet proof, daily it to work.
    Just installed Velocity AP headers back…V12 screams!
  4. GPM
    GPM Formula Junior
    Mar 26, 2015
    553
    Vancouver BC
    dosen't that 6 speed left over from DBS?
  5. GPM
    GPM Formula Junior
    Mar 26, 2015
    553
    Vancouver BC
    after the upgrades, will you be putting a S on the back:)
  6. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,258
    Indiana/North Carolina
    JIM
    Long time owner of a 2007 DB9. Currently installing VelocityAP Headers/Cats/Stainless Exhaust and treating a timing cover leak. Other than that, it's been relatively maintenance free over the past 11 years or so. Absolutely my favorite car that I've ever owned (and like the OP, I've owned or driven some of the best around!).
    Here are some pics from this past week......
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    BJK, Pawilly, peterp and 1 other person like this.
  7. plastique999
    Nov 9, 2008
    8,859
    SoCal
    Edward
    Awesome Jim!
    Let us know how the install goes !
  8. plastique999
    Nov 9, 2008
    8,859
    SoCal
    Edward
    #33 plastique999, Apr 14, 2023
    ? … mine is auto
  9. Frank_C
    Frank_C F1 Rookie
    3,027
    Whistling through the wheat field in Texas
    Frank
    Cool! I just ordered the Velocity AP secondary cat deletes for my ‘17 Vanquish.
    jimshadow likes this.
  10. Alpintourer
    Alpintourer F1 Rookie
    Jul 20, 2013
    3,896
    Sometimes here; Sometimes there!
    Dave Steven
    I own 3 exotics (from the 2000's) that were each $200K new. Two have depreciated by half.
    Sadly, the DB9 has fallen 75%. But that makes them more affordable to you new owners.
  11. jimshadow
    Feb 19, 2006
    6,258
    JIM
    This is my all time favorite car. Perfect blend of elegance and horsepower. :)
    Jim
