Box fuse 355gts 98 | FerrariChat
Box fuse 355gts 98
Discussion in 'Technical Q&A' started by Andrestanley86, Apr 12, 2022.
  1. Andrestanley86
    Jan 7, 2022
    35
    Brazil
    Andre de oliveira carneiro
    Hi, I try to fix a 355gts 98, she have a proble to starter. When starter don't run the air and gearbox. Sometimes don't work starter and run the air and the gear box.
    Have two reley commander this things. Buy the signal I don't know who send.
    I look the workshop manual. But wiring diagram out.
    If possible send me the wiring diagram the box fuse. Ths
    [email protected]
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,745
    Argent/Brasil
    Guido
    Nossa, não entendo qual sao as problemas. A tradução não está correta. Eu também não sei onde obter um diagrama de fiação para a placa de fusíveis.
  3. Andrestanley86
    Jan 7, 2022
    35
    Brazil
    Hi. I serch the problem, in the past someone change the reley.
    I use this wiring diagram. I take in workshop manual 2.
    But it's poor. The last week I repare a testarossa and I take all wiring diagrans, to easy.
    355 is more complicate than testarossa.
    I hope you indentific your problem.
    Ths
  4. Qavion
    Qavion F1 World Champ
    14,536
    Ian Riddell
    #4 Qavion, Apr 13, 2022
    Guido, I'm having problems understanding Andre's english. Maybe you could translate for me? "Air and the gearbox"?
    Here is the wiring diagram which includes the starter, but there are variations. Some '98 cars have a start relay near the passenger footwell, some don't.
    https://www.dropbox.com/t/EaNlyqlV7Mtl6wbk
    Andre, do you have a 355 F1?
    Andrestanley86 likes this.
  5. Qavion
    14,536
    Ian Riddell
    Here is the start relay on some '98 cars
    The photo shows a right hand drive car. The panel is upside down on a left hand drive car. The starter relay may have a different location on your car or may be completely absent.
  6. Andrestanley86
    Jan 7, 2022
    35
    Brazil
    air conditioning and gearbox.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    I don't understand the problem statement so I cannot help.
  8. Andrestanley86
    Jan 7, 2022
    35
    Brazil
    Yes, I don't know how interfere in this reley and another diode reley.
    But someone change the two right up reley in the box fuse. Use the final number 140. And my stayed 103. After I change the car works perfect
    Qavion likes this.
  9. Andrestanley86
    Jan 7, 2022
    35
    Brazil
    When the car start engine my gearbox and air condicion don't work.
    Sometimes the car don't starter and the air and gearbox work perfect.
  10. yelcab
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    What does that mean the Gearbox does not work?
  11. Andrestanley86
    Jan 7, 2022
    35
    Brazil
    no gear enters
  12. yelcab
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    So you have a 355 GTS with F1 gearbox. The problem is when the engine is turning with the starter, no other electronic devices work. Is that it?
  13. Andrestanley86
    Jan 7, 2022
    35
    Brazil
    Yes, all this problem it's because this two reley stay wrong
    Qavion likes this.
  14. Qavion
    14,536
    Ian Riddell
    The Motronic 5.2 ECU relay (E13/M) and the Fuel Pump relay (E2/N) were the wrong type or broken?
  15. theunissenguido
    Jan 21, 2004
    2,745
    Argent/Brasil
    Guido
    Typical error when working on electrics not knowing what they do. Seems all fine now. One more owner that is happy.
    Sorry guys, I was'nt around for some days.
    Qavion and f355spider like this.
