Boxer Battery Disconnect | FerrariChat
Discussion in 'Boxers/TR/M' started by Drew Altemara, Jan 21, 2009.
  1. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Is there a good way to install a battery disconect on the Boxer? With the battery located deep down in the front deck lid under the spare its a real pain. I remember some of the 308 Quatrovalves had a disconnect under the front lid that was very accessible. Just wondering if anyone had a good solution.
  2. donv
    donv Two Time F1 World Champ
    26,119
    Portland, Oregon
    Don
    Do you keep your spare in the car? I keep mine in the garage, which gives me both a usable trunk and a fairly easy path to connect my battery tender.
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,461
    Canada
    Newman
    Mine has a switch mounted on the rear wall of the compartment in the little flat area between the left inner fender and the narrow veritcal hump. Its about a 4" wide area and thats where mine is. I find it handy for when the boxer is under the lift so the clamshell is limited to how far I can open it. I open slightly, reach in and flick it off.
  4. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I just hard wired a battery tender lead to the battery so I can hook it up without removing the spare...
  5. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Same place on mine...It was there when I bought the car.
  6. willrace
    willrace Three Time F1 World Champ
    34,979
    North Tay-has
    Kurt
    A PO installed mine up under the dash, on the firewall I believe (I'll look later and correct if I'm wrong). It's in line with, and just ahead of the Ignition Key location about a foot or so, and can't be seen unless you're looking from a very low angle, and know what you're looking for. Easy to pop it in sitting in the seat without having to see it.
  7. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Mine sits under a 4 post lift as well. I like the left inner fender idea as well. Do you "switch" the red or black wire?
  8. Zarathustra
    Zarathustra Formula Junior
    May 7, 2006
    875
    Hawaii
    Gary Robinson
    I mount Boxer disconnects (with the removable red key) on the left side of the tool-roll well under the spare through the fiberglass.
    That way you don't see it and you can still stick your hand through the spare's spokes and reach it without removing the spare.
    It's also terribly easy to run short battery cables to and from the switch in that location.
  9. Newman
    Dec 26, 2001
    14,461
    Canada
    Newman
    I didnt install it and never looked but I would switch the ground, its easier.
  10. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Thanks gentlemen. I've got some good ideas now. I want to do this in the simplest, least obtrusive way possible.
    Newman, I kinow you and David are buds so take this with a grain of salt. However David advises that only slower injected cars should have the disconnect switch wired through the ground. :)
    Stay warm.
    Drew
  11. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,739
    NYC
    Buzz
    PO put my battery cutoff just behind the utility lamp socket on the bulkhead. Reach down, turn left, lights out. Done.
  12. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    My disconnect is located on the left headlight assembly frame. Nicely done job. Switches the positive terminal. I thought it was factory but i guess not.
  13. Newman
    Dec 26, 2001
    14,461
    Canada
    Newman
    The 365's dont require a battery cut-off because they're usually in pieces undergoing repair.....carbs one week, pumps the next, master cylinders and boosters, on-going suspension, the list goes on.....:)
  14. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    A small price to pay...
  15. Newman
    Dec 26, 2001
    14,461
    Canada
    Newman
    For what? I like to drive my car not fix it all the time! lol.
