Boxer engine out... | Page 3 | FerrariChat
Boxer engine out...
Discussion in 'Technical Q&A' started by robertinOK, Jan 11, 2006.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    Hi Robert, nice work. One question, are you pulling the heads off? The reason I ask is because of the option to change the valves now before they cause you grief. The tight clearances makes me want to pull the heads and set the valve heights back to max spec and run the thickest shims I can for plenty of adjustment down the road so to speak.
  2. robertinOK
    robertinOK Karting
    Dec 5, 2003
    209
    Stillwater, Oklahoma
    RobertWakeling.com
    Ok...spent the evening drawing cam timings and 91tr is spot on...I hadn't factored in the 46deg included angle between the valves; the valves now match my drawings 100% ...relief! Thanks for the input.
    Having got the engine stripped so far it is tempting to go further....but where do you stop? Most of the valves are pretty good, only two are serious cause for concern, and I don't think they would have caused damage, and apart from the bad seal around the clutch the whole engine is oil tight and all bearings and seals seem to be fine. I hate to think of the cost of new valves, guides, machining etc, especially when I think it's not needed. And hey; I can always pull the engine again, it'll be much easier the second time!
    I need to refinish the cam covers and the inlets / plenum and have been considering anodizing them. I do a lot of anodizing work for my company and the finesh is so much better than paint...any thoughts? Black for the covers, nayural ally for the inlets / plenum.
    The inside of the cam covers has an unusual brown finesh which is about to flake off one cover....not a good situation! any idea why it's painted (I think)?
    Again, anodising (after bead blasting) would seal everything up great.
    I've got other jobs on today, but will be tinkering all day too!
    Many thanks for the support guys; it does help!
    Robert
  3. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    I think you will find boxer owners will chime in here and tell you to pull the heads at this time. The clearance isnt so much the issue, why the clearance is tight is the question and when (not if) a valve head falls off, you will regret it because the cost can be staggering but a lot less now before it breaks. Of course its your choice but if you wait for it to break to go in a second time you will kick yourself.
  4. BigTex
    79,406
    Houston, Texas
    Bubba
    I was going to ask about that...is there a way to visually inspect and confirm/deny sodium filled valves???? They may have already been changed.....
  5. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Head work will cost several thousand including gaskets, I wouldn't worry about it unless you think the seats or guides need replacing, if the guides are worn the valve cant dissapate heat as well and can break.
    Its rare for a Boxer to have a sodium valve break more common for 308s as they rev higher among other issues perhaps including Flat 12s have better valve guides so the valves can dissapate heat or the oil circulates better in the guides keeping them cooler as well, its also interesting to look at the cam belts and tensioners path its fairly direct without much bends in the belt vs the 3xx motors, probably another reason cam belt failures are more rare on the Flat 12s.
    How long do you think it took you to remove the motor all together?
  6. steveirl
    steveirl Formula 3
    Dec 29, 2003
    1,163
    ireland
    steve
    Thanks for the great thread and pics Robin, as a boxer owner this is seriously interesting, i may attempt the engine out service on my car when its due and this all helps.
    i have one question though, what have you used to cover your garage floor? It looks great.
    Steve
  7. robertinOK
    robertinOK Karting
    Dec 5, 2003
    209
    RobertWakeling.com
    Total time to remove the engine, from running car to it being on the garage floor is about one solid day...it might be quicker the second time around!
    I notice in the workshop manual they sugest checking the condition of the belts (not changing them) every 15,000 to 20,000 km....(every 10,000-12,000 miles): this is a lot different to the 'every 3000' that gets quoted on here repeatedly.
    The garage floor is composite tile (like in wall mart). The local votech are making alley 'machine plate' covers to go full length over the expansion joints in the floor, all around the pit edge, and at the entries into the garage. Laying the tiles is easy providing the floor is in excellent shape...the tiles will show every bloody irregularity on the floor! The floor is very easy to clean and comfy to sit on...just as well.
    The coating inside the cam covers is a special paint used to stop oil sticking to the rough ally surface (also used on many race engines). I've been told by my anodizers the castings won't look good, so it's back to powder coat!
    Robert
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Yes, what type of cleaner are you using to scrub the castings?
  9. BigTex
    79,406
    Houston, Texas
    Bubba
    There's a Boxer on "the other site' that suffered a broken valve after engine service......pics are not pretty.
    I was thinking of glyptol paint when you mentioned it....common in hi po applications to hasten oil drian back......
  10. robertinOK
    robertinOK Karting
    Dec 5, 2003
    209
    RobertWakeling.com
  11. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    The boxer on the "other site" is also posted on this site and the engine had been rebuilt by a reputable ferrari engine builder that felt the valves were ok at the time. Skimping on that detail (for any reason) caused a lot of grief for the car's owner im sure. When my engine comes out, it will get valves so I can drive with piece of mind, thats worth the expense as far as im concerned. Im also not convinced it would be several thousands of dollars to do the top end but it would be if a valve head fell off, to each is own.
  12. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Lets add up how much it will cost
    24 new valves @$50 each $1200
    24 valve guides @$20 each $480
    24 valve seats @$15 each $360
    2 head gaskets @ $200 each $400
    Machine work $1500?
    I am adding up close to $4000 for new valves
    And yes the 512BB on the other site suffered a valve failure after a full rebuild from Carobu Engineering who reused the valves and did a valve grind on them shortening the valves life further.
  13. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Guess you are right, let it drop a valve first then fix it cheaper......right?
    You are getting it up the chute for machine work by the way and it might not need guides and most likely not seats either.
  14. robertinOK
    robertinOK Karting
    Dec 5, 2003
    209
    RobertWakeling.com
    I've been doing a little research regarding the valves. It would appear the failure rate is very low on the Boxer. The guy whoose engine just blew already had the valves out of his engine (why not just replace them by that point?) and I wonder if in re grinding them etc soemthing went awry...seems a bit of a coincidence they failed just afetr being rebuilt. Sodium valves don't seem to be any worse than any others in terms of failure, and many engine use them.
    I did speak with SI, whilst they don't have Boxer valves, they quoted $13 each for generic SS valves which I can grind to size. (makes you wonder about $50 for Ferrrari valves?) I would not expect the guides or seals on a 20,000 mile engine to need replacement, but would expect to recut the valve seats. My local shop (whome I have total faith in) will ream the valve guides, grind the valves and cut the seats to match for under $200 / head....not sure where the $1500 machine costs come from.
    So, I'm going to do a leak down test on each cyl. If it's good, I'll leave them, if it's poor, it'll be new valves all round. I'll let you know the results....
    Should I take the pistons out whilst I'm there.....
    Robert
  15. BigTex
    79,406
    Houston, Texas
    Bubba
    Glad I could help on the paint info.....listen I'm no expert, don't mean to imply such......I just try to be aware of the issues.
    Absolutely correct the sodium valve technology is still applied in some engines to this day, so it may be best left alone. As far as I know both my 1977s are still equipped with them....
    My understanding on my old 308GTBs is that disabling the air injection reduces the stress on them also. I think your reasoning is good, proper adjustment will insure good contact and heat transfer.
    Valve guide work would only be indicated if excessive leakage and smoke was a problem. I think there is a better seal over stock some have fitted, but this was on older 12 cylinders. Never heard Boxers needing it.......
    HTH...
  16. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    No need to pull the pistons out, just do a top end job and plop it back in. Sodium valves are old technology and like any other engine part in a 24 year old car, they are 24 years old. They become brittle because of the heat cycles and age doesnt help. To me its a no brainer and there is no external test that can detect a valve that will break in 5000kms. If you decide to leave them in then I wish you luck because its not an "if" its a "when" situation just like a timing belt or any other wear item.
  17. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    If you can get it done for under $1200 I would do it, you are getting a great deal on the machine work I hope they are good, it would be an expensive mistake if they messed up a head.
    I would also check the springs as well, I think Ferrari has the guildes a bit loose from the factory so I would replace them as well.
  18. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,879
    Newman - I have enjoyed and learned a great deal from your posts over the years, but now must ask a question concerning your comments vis-a-vis sodium filled valves in Boxers.
    If I understand correctly, there are 24 valves in each Boxer, and there have been approximately 3,000 produced (engineering approximation). Let's see, that means that there are 3,000 x 24 = 72,000 valves in these cars over an average of, say, 25 years. You suggest that the valves are prone to becoming brittle owing to hot and cold cycles, and that it is not a question of "if, but when." I commend you on your farsightedness, as it appears that none of your predictions have YET come true.
    As has been attempted with the belt discussion, perhaps we should ask all the Boxer owners if they have experienced valve-stem failure. Anyone out there?
    Please, no offense intended, merely healthy skepticism. I try to place more faith in automotice engineers and the value of experience. The Ferrari engineers who designed these engines stood on the shoulders of then 35 years of prior experience. Yes, mistakes are made, but they most often reveal themselves quickly. In summary, I am not rushing to change my valves.
    Jim S.
  19. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  20. BigTex
    79,406
    Houston, Texas
    Bubba
    *laughing at this line of thought*
    Yes, Frank but they are NEW sodium filled valves in the Z06!!
    ROTFLMAO!
    I'm thinking of all the time I'd save, to trade in my Fcars on one and quit this chatroom.........LOL!
    But I'd still have the hats, jackets, posters and room full of scale models going back to my original Hot Wheels!
    *sigh*
    Jim S.: lies, d@mn lies and statistics! Don't try to muddy this arguement with FACTS! ;)
  21. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    I dont doubt that sodium valves are still used, im sure they are made of a different metal though and lessons learned from the past might make them a better valve today. Like things from the past that failed such as the 4/6/8 electronic cylinder cancelling has now become the cats a$$. Same idea, better technology. A valve head falling off in a boxer engine isnt new, not a daily happening but then again, how many are driven out of the 2000 BB's built? How many have been replaced prior to failure and how many cars are actually left alive? Being in the trade myself, I feel my advice is sound and thought I would just voice it seeing as this is the purpose of the site - to help not misguide for kicks. Sorry for stepping on so many toes, I bow out of the thread now.
    P.
  22. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,879
    Newman - don't bow out - your input makes us think. No offense was intended and I hope none was taken.
    BigTex - you're right. What was I thinking? Facts... such a nasty way to settle an argument.
    Newman - Your advice is sound. Who would argue with replacing valves. In medicine, however, we have a saying, "Above all, do no harm." The equivalent philosophy in auto mechanics is, "If it ain't broken, don't fix it."
    What I am trying to convey is that the statistical likelihood of a 25-year old valve failing is less than a new valve failing. The latter will occur as a result of a manufacturing flaw, or an error in installation, or seat incorrect, etc. The real advantage of a 25-year old valve is that it has proven NOT to have a manufacturing flaw. Again, in medicine, we say that "...it has withstood the test of time."
    This is different than normal wear that leaves the stem diameter less than specification, which would require replacement. However, in the absence of normal wear rendering the part terminal, I would not spend the money or time replacing perfectly good parts.
    Jim S.
  23. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,349
    Austin, Texas
    David Castelhano
    I share Newmans views on sodium filled valves having seen failures caused by the valve stem weaking from the inside. Metallurgy has made some giant improvements since those valves were manufactured.
  24. robertinOK
    robertinOK Karting
    Dec 5, 2003
    209
    RobertWakeling.com
    OK....I've decided to pull the heads and replace the valves.
    Looking at the valve clearances, the two that are small seem very different to the others, so it might indicate a problem. I will do a leak down test tomorrow, but even if it shows good, it is no gaurantee the valves are not 'elongating'
    So tomorrow I'll remove the intakes, regulators, pull the heads and see what's what.....expect a few more pics....
    R
  25. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Let us know how hard it is to remove the heads, I know it takes a puller on some to remove.
