Boxer modded brakes | FerrariChat
Boxer modded brakes
Discussion in 'Technical Q&A' started by atheyg, Feb 9, 2005.
  1. atheyg
    atheyg Guest
    #1 atheyg, Feb 9, 2005
  2. Martin Meade
    Martin Meade Karting
    229
    B'ham, WA
    Martin Meade
    Between Eric and Myself, we can probably figure it out but I need a better look at what you have. Either rotate the wheel or remove it to get a better shot.
    Martin
  3. boxerman
    boxerman F1 World Champ
    19,921
    FL
    Sean
    Do they work well?
  4. Martin Meade
    229
    B'ham, WA
    Martin Meade
    I have no clue what they are or how they work. Are you having problems with them? Can you post a better picture, with the wheel off?
    Martin
  5. atheyg
    atheyg Guest
    Hi
    I recently had a small engine fire and am dealing with getting some replacement wiring and safety wiring the carbs etc., I have not had the wheel nuts off the car yet, I tried with the factory wrench to no success so I need to get a big socket with a cheeter bar to take them off, its on my list to buy after I get the wiring fixed so I can get a better pic of them.
    Concerning how they work the pads must be a metallic racing type so they squeal alot and need to be driven hard to make them work well, so for the street I don't like them and would like to replace them, the brakes do work excellent though the limitations are clearly the P6 tires that are on the car and I am going to replace them with something more meaty such as a 275/60/15 on the rear and modern so I am sure it will make a major difference then also.
    I would like to find out what they area also, a PO spent some big bux supposedly on the brakes having them custom modded and made, I don't know the history of them or what was done, the brakes do look good drilled on the car though and adds a nice touch, this was done when drilling was the rage and only choice.
  6. Rifledriver
    37,288
    What do you guys have to offer in good brakes for a BB?
