Buy
Boxer owners ?
Discussion in 'Technical Q&A' started by parkerfe, Mar 30, 2004.
  1. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Are you using a 0.9 bar or 1.1 bar radiator cap? The manual calls for a 0.9 bar cap, but TRutlands has advised that a 1.1 bar cap will keep your car a little cooler.
  3. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,870
    I found that I lost coolant with .9 Bar. However, the expansion tank "balloons" when using the 1.1 Bar. I have had two expansion tanks balloon with 1.1 Bar, and numerous other owners have commented on it. Seems to be a design flaw.
    Jim S.
  4. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I use the 1.1 bar and have no problems with the header tank ballooning. It seems to me that a hose would burst before the steel header tank would balloon ?
  5. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,425
    Tuscaloosa, AL
    Drew Altemara
    1.1 bar is what my cap reads.
    Drew
  6. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,870
    One would think, wouldn't they. However, the internal surface area of the header tank, and its large flat surface (relative to the cylindrical shape of a hose) lends itself to "expansion." I have seen these tanks expand on several Boxers, not to speak of two of my own. I replaced my tank with a brand new one (as it was leaking), and within a few miles of initial use the new tank had expanded. Take a close look at yours to see if it is distorted.
    Jim S.
  8. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,476
    Cape Canaveral/Atlanta
    Walt P
    I would think the lower the pressure the better it would be on all your hoses and expansion tank. I don't believe adding pressure increases anything but the boiling point which can give you a safety margin if you are running straight water with no anti freeze and are close to 212 degrees.
  9. kdross
    kdross Formula Junior
    880
    NJ
    Ken
    I have a 308QV and just ordered a new radiator cap from Algar. My old cap was rated at 0.9 bar, and the new one was rated at 1.1 bar. I called Algar and they told me that the .9 bar cap had been replaced and "updated" with the 1.1 bar cap by Ferrari. So as of today, the 1.1 bar cap is the OEM cap for the cars.
    Ken
  10. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,095
    Seattle
    Gary
    Frank,
    My cap is stamped 1.1 and I haven't had any cooling problems at all.
  11. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,870
    Walt - while the coolant at the transducer may not be at 212 degrees, the water flowing past the combustion-area may be at a higher temperature. The system is closed, thus the pressure is uniform throughout. As mentioned, this raises the boiling temperature (pressure being an independent variable, along with molar concentration of antifreeze as an independent variable). Thus, the greater the system pressure, the less likely is local boiling. The downside to much greater pressure is hose integrity, propensity for leaking, and water pump efficiency.
    I have heard that the factory had called for 1.1 Bar caps to replace the .9 Bar caps. My experience of venting at normal operating temperature supports this recommendation. The only downside has been the ballooning of the expansion tank.
    Jim S.
  13. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,476
    Walt P
    I agree with what you are saying. That is why I said the lower presure the better IMO. This would possibly make it necessary to keep the anti freeze up a bit. When I was a kid and my Firebird had a radiator leak I would run without a cap at all to keep from pushing the water/anti freeze mix out and never once overheated. I did have to add water to make up for evaporation.
    Walt
  14. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    The BB512i manual does call for a 0.9 cap and TRutlands does have them for sale. My car currently has a 1.1 cap on it.
  15. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,476
    Walt P
    The difference between 1.1 bar and .9 is almost 2 psi and when you figure the surface area of the expansion tank that is quite an increase. The boiling boint of water only (no antifreeze) goes up from about 245 degrees at .9 Bar to about 251 degrees at 1.1
    I don't see the advantage of increasing the pressure but I'm sure Ferrari has a good reason.
