Epoxy primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Engine prepped for paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Originally we wanted to powder coat the engine block. After reading into it further we found some concern that powder coating traps heat inside and raises the engine temp. We decided to go with a standard engine paint with a good primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Engine block painted. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Just a detail but make sure that the frost plugs are painted black after installation. They are supposed to go the colour of the block as they were installed by the factory prior to installation. Looking good nevertheless
Epoxy primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Skim coat of body filler to smooth out the metal work on the tanks. Image Unavailable, Please Login Image Unavailable, Please Login
Were the wheels painted metallic originally or staight silver like the cromodoras? Also, block was black, not silver? Ed
Individually sanding all wheel surfaces smooth. We are 3 days into sanding alone. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Amazing thread and work. It was a pleasure to find this thread and be able to go through all the hard work and pictures. I cant wait to see the final result!!
Wonderful wheels with the rare "Dino" and "Campagnolo" words both in the casting. Nice prep work, keep it up guys! Would it be an imposition to ask the paint code as I need to do mine also?
@ synchro, see post 286 for paint code. Can you confirm that the wheels were orig painted metallic silver or semi gloss nonmetallic silver? Ed
We plan to touch up the block after we get the rotating assembly installed and heads on. Did you guys have any trouble pulling out your plugs? These were a nightmare.
Original paint was a single stage so it would have no clear. The paint code shown on the can is not complete. I will post the full paint code shortly.
More sanding. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Urethane sealer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
First coat of paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sanding gas tanks down. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
