Door panels removed to be reupholstered. Image Unavailable, Please Login Image Unavailable, Please Login
Wet sanding guide coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Skim coat of body filler. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sanded down. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
We fabricated brackets to hold on the parts in the spray booth. This will allow us to paint everything in one shot. Humidity and temperature have an effect on color so it's important to paint at the same time. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Parts ready for paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The oil and spark plugs had a strong fuel smell. We found the issue to be a broken hose off the fuel pressure regulator. Image Unavailable, Please Login Image Unavailable, Please Login
We originally found 6 bad lifters. After sitting for a few days the final count is 12. They will be sent for rebuilding. Image Unavailable, Please Login
Lower timing bearing in need of replacement. Image Unavailable, Please Login Image Unavailable, Please Login
We noticed the engine oil had signs of water contamination when dumping all the fluids. Originally we ignored it as condensation until we started to see the same issue inside all of the engine internals. The car ran really well and did not smoke or consume coolant. We will do some diagnostic work to find out if this is an issue. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
After sitting for a few days you can see the oil and water separated. Image Unavailable, Please Login Image Unavailable, Please Login
This is what it looked like when it was still hot. Image Unavailable, Please Login Image Unavailable, Please Login
