News
Bradan BMW 7 series accident repair
Discussion in 'Bradan' started by BRADAN, Oct 2, 2018.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  2. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  3. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  4. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    12,448
    Wow that's crazy the car is damaged and so new. Was it damaged in transport to the dealer? I can see that airbag warning tag hanging off the glovebox area so it looks like a brand new car and not used/sold.
  5. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
    400 miles on the car. It was hit on the side driving in traffic on the GW bridge.
  6. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  7. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  8. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  9. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  10. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  11. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
    BMW recommends self piercing rivets over welding on most body repairs. The reasoning for this is welding can potentially weaken the metal from heat cycling and burn off corrosion protection on the rear of the weld. The 1/4 panel was glued on using BMW structural adhesive then riveted in OEM recommended location with BMW rivets. Its very important to make sure your collision repair center has the correct equipment to properly repair your vehicle and follows OEM repair procedures.
  12. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
    Originally BMW recommended just gluing the 1/4 panel exterior connections with K2 structural adhesive. The issue was on pearls and silver paint you could eventually see a ghost line of the repair area. So if the repair procedure is searched via vin number you can see they now recommend welding in the connection areas. Its important to have the correct welder for high strength steel and aluminum.
  13. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  14. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  15. BMW.SauberF1Team
    Dec 4, 2004
    12,448
    This all seems pretty expensive from an insurance point of view. Why was it not written off? What percent of retail value do they typically attempt to repair it? The damage of course does not appear structural, but I see hail damaged cars written off simply because cosmetic repair (like this) is too expensive.
  16. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
    Every state is different as far as total thresholds. NY is 75% of the cars value but theres other factors that determine if its repaired or totaled.
  17. BRADAN
    Sponsor
    Aug 29, 2009
    21,960
    West Babylon, NY
    BRADAN
  18. Michael_s
    Michael_s Rookie
    Oct 20, 2013
    19
    NNJ
    You guys do unreal work.... I'm in NNJ and will def call you if needed. The attention to detail is amazing.
