5 series accident disassembled. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Mini hood repaired and painted. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
New OEM bumper, fender, headlight, and radiator. Insurance paid for all aftermarket parts, non of them fit well and we were able to get the original parts on the car. Door and hood will be blended for color match. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Base color and clear coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Rear ended 535 tail section cut out. New OEM bumper, trunk, and door. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Tail section setup for installation and primed inside for corrosion protection. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Tail section installed with BMW self piercing rivets with BMW K2 structural adhesive. Its important for the structural integrity and long term corrosion protection to follow OEM procedures. Most people ignore this and weld the panel in. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Factory seam sealer installed with etch primer. Corrosion protection is just as important as the structural integrity of a collision repair. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Small scratch on a pearl white 7 series. The full 1/4 panel has to be clear coated to avoid a blend line. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
G30 5 series hood painted. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body prepped for full side paint with new bumper, trunk, door, and fender. Image Unavailable, Please Login
Rear body harness repaired and sections replaced. Modules replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
New panels sprayed with base coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Clear coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Primer and body set up for color blend. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Hood and trunk painted. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body base coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Rear ended 2019 3 series tail panel pushed in. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Rear panel removed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
New OEM replacement tail panel installed using BMW structural adhesive and self piercing rivets. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
To avoid an open blend we will do full 1/4 panel base coat and clear into the a pillar. Base coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
