Bradan Coachworks | FerrariChat
Bradan Coachworks
Discussion in 'Ferrari Discussion (not model specific)' started by BRADAN, Jan 23, 2018.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    Hey guys I am excited to announce we are finally adding collision repair to our paint shop! For the past seven years we have turned down accident repair work because we lacked the equipment to properly repair accident damaged cars, but now we are upgrading the body shop and changing the layout, gearing it towards expansion. This overhaul will benefit both our paint and restoration work while allowing us to add a collision shop. We will be turning nine years old this April, and to celebrate, we are adding collision repair to our list of services.
    We will blog the start-up phase and try to answer any of your questions. We hope you enjoy following the process. Although our collision repairs will be geared towards high-end cars, we are non-discriminatory and will work on all makes and models.
    msdesignltd and JL350 like this.
  2. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  3. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  4. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  5. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  6. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    We relocated our lifts to the other side of the building to create a production line setup. The concrete was only 3" thick in sections so we had to install reinforced concrete pads. 6,000 lbs of concrete, sand, dirty in our tow truck with no signs of slowing down!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  7. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  8. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  9. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  10. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    I flew to Munster Germany to visit the Glasurit factory and get trained in color mixing, blending, and all BASF products. Were certified in there 22,55, and 90 paint lines now. Training and factory support will help us out with older color codes converted from lacquer to solvent based and even water on modern cars.
    It takes a full day to tour the whole factory it's a mini city. Its BASFs center of production, research/development, and marketing.
  11. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  12. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  13. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  14. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Riding the speed limiter on the autobahn in a BMW m4.
  15. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    some video from the Ring.
  16. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Were excited to announce our most recent equipment addition, our CarBench Muraena Jig Bench. Made of German steel and built in Massa Italy, this jig bench allows us to repair exotic vehicles to aircraft precision. Carbench is the only frame jig with OEM approval from Ferrari and Maserati. It also carries other OEM approvals for BMW, Mercedes, Porsche, Lamborghini, Bentley, and Rolls Royce to name a few.
    If you have ever heard that cars are never the same after an accident, that is because other shops are using benches with only 4-10 fixture points. Ours has over 100. That means we can truly restore your vehicle to the same condition it was before collision.
    When shopping for Jig benches viewing the factory was very important to me to understand the company, equipment quality, and all machine features. Carbench was the only manufacture that welcomed me with open arms. Every other brand manufactured there jigs in Indian or China. I offered to travel to the factories regardless and was turned down.
  17. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Car bench writes all the bodywork repair manuals for Ferrari and is the only Jig bench approved by them. They had the F12 superfast in the factory to design all the tooling required to repair it. These are the prototype fixtures.
  18. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Boomhauer likes this.
  19. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  20. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    This is the actual pull post that straightens out accident damage. Every post is made start to finish in the factory and quality tested before shipping.
  21. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    This is the actual jig post that takes most of the stress during pulling. Most manufactures bragged how theres is solid steel and how strong it is. The problem is the pulling power of the pull post is stronger then the jig post. So if you bend a post you have no way of knowing so every car after that is pulled to an incorrect tolerance.
    Carbench made a cast hollow post that intentionally breaks if the pulling force is exceeded. I love the engineering Carbench puts into every single part of the fixture.
  22. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    This is a completed main frame of the jib bench. Lorenzo and his wife own Carbench together and proudly knew every design feature start to finish.
    In this photo Lorenzo is showing me that you can see all the machining marks and welds on the finished product. They dip every bench is a Galvanized bath to prevent rusting. Every other manufacture covers there steel in paint to hide all the imperfections.
  23. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    This shows the original Ferrari 360 modena front frame structure jigged to the bench. When Ferrari originally built the 360 chassis with Alcoa it was solid Aluminum. Carbench had to reverse engineer the chassis and section is to make it repairable in the future.
