Starting with the 360 they are, now they’ve moved on to carbon fiber tubs etc. Your Scud is all aluminum.
Fantastic effort. Would it not have made sense to strip the complete shell based on the level of restoration you are doing. I know there are companies in the UK that do surface reprocessing for full body shells that get done on a spit. The obvious issue is costs as every rubber seal and gasket for the panels needs to be replaced. The hardest part in the 355 is the back window (Not to mention a very expensive one if you break it during removal or refit) , but you have no such issue as its a Spider.
To really get it to a bare shell its a few more weeks of work. The bottom of the car is fine and mostly rust free so we are only doing the exterior.
Hinges removed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body sanded down to etch the surface for primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Water leaking from the A pillar rust pin hole. We will drill a hole to drain it. Image Unavailable, Please Login
Sanding away paint in the corners. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Edge sanding. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
more. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Doors detail sanded and fiberglass detail sanded. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
