Prepping for primer finally. The most important part of the paint job is to get the foundation prepped correctly. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Glasurit metal cleaner. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The multi metal prep wipes apply a phosphate coating to enhance adhesion and corrosion resistance. Similar to etch primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sprayed with Glasurit 801-703 chromated epoxy primer. It has excellent corrosion protection and outstanding adhesion. We use a Sata 100 B F HVLP gun with a 1.3 tip. Booth was 20 percent humidity at 68 degrees. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fiberglass parts sprayed with Glasurit 1006-26 sprayable body filler (polyester primer). It has a high filling capacity and ability to spray heavy thick coats to fill pin holes and level fiberglass panels. I really like it for repairing Gel coat on fiberglass. We used a Sata 100 B F poly gun with a 2.1 tip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Aluminum panels prepped for primer using Glasurit 360-4 metal cleaner. Its a solvent that removes contamination from bare metal surfaces prior to primer. We followed with BASF 2000 advanced prep wipes, its a prep wipe for aluminum that applies a phosphate coating to enhance adhesion and corrosion resistance. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Glasurit 801-703 chromated epoxy primer with a Sata 100 B F gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Doors sanded down and prepped for primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Doors and trim wiped down with adhesion promoter and sprayed with Glasurit 801-703 primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Factory badged fenders provided. We sanded off the factory E-coat to get better adhesion for the primer. Image Unavailable, Please Login
Bumper repaired with fiberglass and skid plates test fit. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumper sprayed with Glasurit Polyester primer with a Sata 100 B F poly gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Filling side markets with fiberglass. Image Unavailable, Please Login Image Unavailable, Please Login
Reflector eliminated with fiberglass. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
