Body sprayed with 285-20 Low VOC DTM primer with a Sata 100 B F primer gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Wheel paint stripped. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
More. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
More paint strip and sanding, notice the corrosion pin holes. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Is that gold coating on the freshly stripped wheel similar to the Dow7 magnesium treatment/preservative?
That’s a ton of work for the wheels. Is there no easier way to get the paint off? Why can’t you just bead or sand blast them?
You can’t sand blast magnesium it is way too soft and will pit like crazy. Plastic media maybe depends on the wheel and how it has been previously refinished. Most aren’t refinished properly. Bradan does the correct job.
That's true but I glass bead blasted a set of mine as final prep once the bulk of the material was removed. No issues. You just need to reduce the pressure.
That coating is on top of the white primer. Here is what Dow 7 looks like (it's a chemical surface conversion done in a bath) Image Unavailable, Please Login
You're right, seems like the wheels may have been painted gold at some point. Thanks for that picture of the Dow 7.
Correct guys the wheels have been painted at some point. I've tried chemical stripping, sanding, and glass dust blasting. Right now we just use a combination of the methods based on how many times the wheels have been painted. We try to avoid media blasting to preserve the factory dow 7 coating if its still there.
Wheels prepped and wiped down with BASF 2000 advanced prep wipes. Its a pre-saturated wipe for aluminum and magnesium. It applies a phosphate coating to enhance adhesion and corrosion resistance. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Wheels sprayed in Glasurit 801-703 Chromated epoxy primer. Image Unavailable, Please Login Image Unavailable, Please Login
Calipers chemical stripped. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Rims hand sanded. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Polyester over imperfections. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Spot with primer break through were primed and sanded again. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
