Glasurit 285-29 sealer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Mixing Argento in Glasurit 55 line Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Calipers sprayed with Nero using Glasurit 55 line. Image Unavailable, Please Login Image Unavailable, Please Login
Wheels sprayed with base coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Base coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Glasurit Clear coat 923-255 Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Thank you keeping the booth and mixing room as clean as possible pays for itself just in the work quality, never understood why guys dont keep up on it.
Wheels dry. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Interior panel black trim paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Panels sanded with guide coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
1/4 panels sanded with guide coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Spraying the body and panels with Glasurit 1006-26 sprayable body filler with a Sata 100 polyester gun. This will level out the metal panels without excessive body filler. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sprayed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
This is the most difficult part of the car to sand. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
1/4 panels sanded. Tape is used to maintain the body lines during sanding. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
1/4 panels sprayed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Door scoops block sanded. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Panel gapping the body. Fenders will be welded in place after we get the lines right. New door pins and bushings installed to eliminate door sag. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fiberglass parts and aluminum deckled setup for poly primer. We switched to Spies hacker for these parts it sprays finer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sprayed and baked. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
