[ATTACH] [ATTACH]
Glasurit 801-703 chromated epoxy primer with a Sata 100 B F gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body cleaned with Glasurit 360-4 metal cleaned followed by BASF 1000 multi metal wipes. The multi metal prep wipes apply a phosphate coating to enhance adhesion and corrosion resistance. Similar to etch primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sprayed with Glasurit 801-703 chromated epoxy primer. It has excellent corrosion protection and outstanding adhesion. We use a Sata 100 B F HVLP gun with a 1.3 tip. Booth was 30 percent humidity at 70 degrees. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Doors sanded down and prepped for primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Used rear bumper stripped, we found minor prior accident repair work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Used front bumper chemical strip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Doors and trim wiped down with adhesion promoter and sprayed with Glasurit 801-703 primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumper strip with prior repair work found. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Factory badged fenders provided. We sanded off the factory E-coat to get better adhesion for the primer. Image Unavailable, Please Login
Bumper body work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The car is parked outside in the sun daily for a week to help all the solvents gas and cure. Image Unavailable, Please Login
Donor front bumper fell apart from prior repair work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fiberglass repair work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Ordered a new bumper and primed body in Glasurit 1006-26 polyester primer with a Sata 100 B P poly gun. The panels were pre cleaned using Glasurit 541 silicone and tar remover. ITs a solvent based cleaner that dissolves wax, silicone, grease, road road, and oils. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Front bumper sanded. We prepped it to spray in the next phase of primer. We used Glasurit 285-20 Urethane primer with a Sata 100 B F gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
