Reflector eliminated with fiberglass. Image Unavailable, Please Login Image Unavailable, Please Login
Euro reflector hole drilled into fenders. Fenders rough sanded and low spot shown as the darker areas. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumper reflectors fiberglassed in and primed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body sanded, low spots are the dark areas that sand paper didn't cover. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sprayed with Glasurit 285-20 primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumpers sanded down for another coat of primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Door block sanded and body work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body panels sprayed with 285-20 Low VOC DTM primer with a Sata 100 B F primer gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Block sanding and welding corners with our Cebora Jaguar pulse mig welder. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Doors and scoops sanded with guide coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Setup for primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body panels sprayed with Glasurit 285-20 low voc DTM primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The F355 Berlinetta and GTS have a common crack area on the 1/4 panel, this is caused by flexing between two panels. We dig all the material out the crack and prep it for welding. Welding will reduce the flex between the whole panels, hopefully resolving the cracked paint issue. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Test welds using the same gauge metal to dial the machine in. Image Unavailable, Please Login Image Unavailable, Please Login
A lot of guys send me Pms and emails asking for specific materials we're using in the shop so I included most of it to help answer potential questions. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Battery removed and all computers disconnected to avoid electrical issues from welding. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
If you look closely at the panel you can see a bronze weld in the flex areas from the factory. Being over 20 years old its more than likely this was originally Mig brazed. Image Unavailable, Please Login
We used a technique called back purging which uses the same 100 percent mixture of argon gas as a shielding gas on the back side of the weld to avoid corrosion from mixing with oxygen during welding. Remember, corrosion protection is very important when doing any welding on the body. Corrosion on the back side of the weld will cause a failure. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
