Used front bumper chemical strip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fenders wiped with adhesion promoter and sprayed in Glasurit 801-703 primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Prior repair work found on the used front bumper. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Factory badged fenders provided. We sanded off the factory E-coat to get better adhesion for the primer. Image Unavailable, Please Login
The car is parked outside in the sun daily for a week to help all the solvents gas and cure. Image Unavailable, Please Login
The used bumper was defective and falling apart from prior repair work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fiberglass repair work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Did you fill in the European side indicator on the fender? Wow, I would have kept that if so and actually fit the indicators.
Ordered a new bumper and primed body in Glasurit 1006-26 polyester primer with a Sata 100 B P poly gun. The panels were pre cleaned using Glasurit 541 silicone and tar remover. Its a solvent based cleaner that dissolves wax, silicone, grease, road road, and oils. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The new bumper is an aftermarket piece? If so were you pleased with the quality? And the plan it seems is to run euro front side markers in the fender, (and none in the front bumper) but keep the side markers in the rear bumper? Thanks for all the pics!
Braden, did all model years of the F355 come from the factory with basecoat/clearcoat or were some single stage?
It was OEM euro spec, as you can see it comes in needing minor body work. Yes were removing all the side markers and going euro style. Thank you!
Front bumper sanded. We prepped it to spray in the next phase of primer. We used Glasurit 285-20 Urethane primer with a Sata 100 B F gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Reflector eliminated with fiberglass. Image Unavailable, Please Login Image Unavailable, Please Login
