Checking temp sensors. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Engine and trans mounts replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Black trim paint and skid plates installed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
This annual service turned into a major service. We had it idling on the lift to warm it up and dump the fluids and noticed a steady oil drip. Originally I thought it was a leaking line but found it was coming from above. This car had a major service as part of the sale and it looks like it has a ripped cam seal. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Some people believe that the case of the O2 sensor needs to be grounded through a separate wire. I suspect that wire will be connected to a chaise ground somewhere.
I didn't like how the prior primer dried so we started over. The surface was wiped with BASF 2000 metal prep wipes. Its a pre saturated wipe for aluminum and magnesium. It applies a phosphate coating to enhance adhesion and corrosion resistance. Followed by Glasurit 801-703 zinc chromite primer sprayed with a Sata 100 B F HVLP primer gun. Glasurit 801 has excellent corrosion protection, outstanding adhesion, and good solvent resistance. We love it. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Metal body filler and sanded for the next coat of primer after bodywork. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Wheels sanded and prepped for the next stage of primer. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Primed with Glasurit 285-20 using a Sata 100 B F primer gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sanded with guide coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Mixing Argento in Glasurit 55 line solvent paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sprayed with base coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Which is better, the Bonderite Mag coating or the BASF 2000 wipes? Could/should they both be used together?
Amazing work. what is this rotary sanding machine ? can you PM me or share here more details about it
