Bradan F355 Brake Lines | FerrariChat
Discussion in '348/355' started by BRADAN, Jul 18, 2010.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    #1 BRADAN, Jul 18, 2010
    These sturdy, stainless steel brake lines are a direct replacement for the
    factory-standard rubber lines typically used by most vehicles. Unlike the
    standard components, the material in stainless brake lines won’t expand
    through normal use, significantly improving both pedal feel and
    deceleration response time. Additionally, stainless steel provides a much
    more reliable and consistent product, preventing deterioration common in
    rubber components. Our brake lines feature an interior PTFE hose covered
    in a stainless-steel weave, treated with a translucent, abrasion-resistant
    coat. Lines are burst tested up to 3,000 PSI, and fully DOT
    compliant (MVSS-106).
    $195
    First 10 buyers receive discounted price of $145. Call 631-585-8600 to order.
  2. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    Nice. When I changed the brake lines on my motorcycle to stainless it made a huge difference in feel. I'll have to think about this for when it's time to do the next brake fluid change on my 355 spider.
  3. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    I was wondering if these did in fact make any difference in the feel.
    Sounds like a CHEAP price to pay for a little better performance, no?
  4. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    do they work on 348's??
    Kai
  5. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    Any discernable advantage over Stop Tech? MSRP is pretty much identical.
  6. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    These do fit the 348 also.
    I noticed a huge change in pedal feedback on our F355. Keep in mind though we do have very high miles and I doubt the stock lines have ever been changed.
    Goodridge is well known for producing top quality lines for motorsports. They manufacture our lines. To be honest though most lines are similar in quality at this level.
  7. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #7 BRADAN, Jul 19, 2010
    It is a matter of remaining consistent over time and under race conditions. There are many variables that would affect if you feel a difference or not. Its not a simple yes or no answer.
    We have sold 4 sets since this morning. We really appreciate the support from the community.
  8. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
    The regular rubber brake lines do eventually wear out too, I was thinking of it partly as an upgrade, but also as preventative maintenance.
  9. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    2 sets left at the sale price.
  10. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    This is a HUGE deal. I already bought mine last month from the competition. Too late for me, but somebody JUMP on THIS!!!
  11. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Last set for sale at $145.
  12. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  13. gcthree
    gcthree Formula Junior
    Jul 18, 2008
    323
    Williamsburg, Va.
    #13 gcthree, Jul 24, 2010
    Lines are installed, and the pedal is certainly firmer (as expected).
    I installed Speedbleeders (see photo) all around at the same time, making the bleeding exercise after installing the brake lines so much easier. The bleeders are polished stainless steel, and you loosen them 1/4 turn, get in the car and pump the pedal (remember to have the key turned to the 'run' position) 3-4 times, and then close the bleeders. Done!
    I bought their bleeder bag, and it is an inexpensive and terrific companion to the bleeders.
    The brake line install is pretty straightforward, other than the female fittings on the Bradan lines are slightly shorter than the stock lines, and you'll need to put a little effort on the steel lines to get them to mate. Otherwise, they are really well done line.
    When breaking loose the fittings, get an 11mm brake nut wrench to ensure it doesn't slip and round the fitting. You'll also need a 17mm open-end wrench to hold the female fitting on the lines. Break them loose first, then remove the clip that holds the line to the bracket. On the install, push the new line through the bracket and capture it with the clip; then thread the hard line into the new sheathed line. Make sure you tighten it back up, and use the 11mm brake nut wrench. The pictures are of the rear of my car; the front is much the same.
    Great product at a very fair price.
  14. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    Which Speed Bleeder P/N did you use and does it work for 348's as well?
    Kai
  15. Sandy Eggo
    3,636
    Encinitas, CA
    Rick
    ^^^^^^^^^^^^ This
    Even though FBB advised me on the correct way to do things, the 11mm end was so frozen and stripped that I was able to instead get the 17mm end moving - so I just went with it.
    Resist all f-ing temptation to do anything with the 17mm wrench besides hold the female fitting while you work the 11mm end free.
    Let me just emphasize that if you don't follow this procedure, your day will end very badly. Ask me how I know...the good news is that the brake line you just f-ed up is only $25 from Ricambi. :D
    Instead, if that 11mm end won't move then apply some WD-40 and some heat to loosen that SOB up.
  16. gcthree
    Jul 18, 2008
    323
    Williamsburg, Va.
    Not sure if the 348 and 355 calipers are the same; if they are, I used PN: SB1010S-SS (SS for stainless steel). The stainless were $15 each, and you'll need 8 fittings.
    Regarding the 17mm wrench....YES, you do not turn the female fitting, but use the wrench to offer resistance to the torque from the 11mm wrench as you break it loose. I found my fittings to be very easy to release. But I emphasize having a specific brake fitting wrench to ensure you do not mess-up the nut.
  17. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    does anybody know if the brake calipers are the same and/or the bleeder valves are the same size for 348 and 355?
    Kai
  18. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    The bleeder valve is OEM part #152954 UNION. A quick search shows that they are the same.
    Thank you for posting Bob.
  19. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    Awesome.
    found the speed bleeders on ebay for $12ea.
    Kai
  20. fatbillybob
    Aug 10, 2002
    29,249
    socal
    #20 fatbillybob, Jul 26, 2010
    There are a couple problems with the ferrari lines:1) they could be bent from the factory in a way to encourage the 11mm nut from riding on the tubing and galling on it. 2) there could be factory undercoating on the brake line 3) the dang thing is corroded on there from the factory application of 1 million ft-lbs.
    The solution can be penetraing oil, heat, heat w/ oil and the proper tools. An open end wrench is fine unless you need more torque to get the nuts loose then you need the proper tool which is a brake line flare wrench as pictured below. You can see the narrow wrench vs the flare wrench thickness to support the nut and the 270 degree surround of the flare vs the open end wrench. These just happen to be the Ferrari F1 factory tools from USAG. They happen to fit better on Ferraris than anything else I have tried but they don't have the stoutness of snap-on.
  21. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #21 drbob101, May 28, 2013
    I wanted to resurrect this thread as I used it for guiding me in the project I just completed and I had a couple observations that others may find useful.
    First off, I had Bradan repaint and refurb a set of 355 Calipers that I had . I have black ones OEM but wanted to try yellow and didnt want to permanently alter by OEM.
    They did a SUPERB job on the calipers. Media blasted, powder coated and clear coated. They looked beautiful. New piston seals and bleeders where needed as well. Great job and Dan is an attentive, knowledgeable guy.
    I bought the Goodridge Phantom brake lines. They are SS coated black. Nice product.
    Goodridge Fluid Transfer Systems
    On to the install. I went and bought an 11mm flare wrench from Napa and started in. The first fitting to break was the right rear and it was a disaster. From try one wrench turned on the nut and I was a mess. Vise grips and a lot of frustration and I got it loose but said there is no way I am doing this all around. I called Dan late Friday afternoon as he was good enough to give me his cell and he said get a Snap On wrench. It you cant get one I will Fedex overnight one next week.
    I tried again with a tighter fitting open end 11mm but could not break it and had no confidence in the feel of the wrench on the nut. I put PB Blaster and heat on it. Still nothing.
    To the internet and I found a Snap On dealer on Saturday morning and went to his house and bought the 11mm wrench and the 11mm claw type. NOt cheap but I went home and put that wrench on the nut and actually had to tap it in place as the tolerances were so close. When I put my hands on it just by the feel I had the confidence to go with it and it broke the nuts in 2 seconds.
    The Snap On dealer explained to me that their closed wrenches have the female pointed areas rounded so the nut doesn't hang on that area and you get just flat on flat. I have some pictures below of that area just FYI. The claw type was very useful on the front brake line joint right behind the rotor. YOu put a 3/8 extension and ratchet on that and you have great clearance with your hands.
    In a nutshell. IMO, do not attempt doing your brake lines without a Snap On flare wrench!!
  22. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bob, you should post a photo of your calipers here...
  23. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I would Dave but my phone went swimming and so did all my pictures!!
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #24 Dave rocks, May 28, 2013
  25. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
