This F355 came in for a routine major service. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Front timing drive bearings found to be leaking. The engine bottom end will be resealed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Timing cover removed. Wear found on the oil pump chain tensioner. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Leaking gearbox cooler found. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Intake leak found notice the black exhaust port on the same cylinder. Image Unavailable, Please Login Image Unavailable, Please Login
Lifters rebuilt. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Oil filter housing gasket and gearbox cooler replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Rebuilding timing cover with hill engineering bearings. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Oil pan installed. Hill engineering tensioner bearings, OEM tensioners, timing drive pulleys tack welded. Image Unavailable, Please Login Image Unavailable, Please Login
Valve covers repainted wrinkle red with a dust coat of Rosso Barchetta single stage glasurit 22 line. Image Unavailable, Please Login Image Unavailable, Please Login
Closed up. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Convertible top pump rebuilt. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Filled up and road tested. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
