Bradan F355 paint correction | Page 2 | FerrariChat
Discussion in '348/355' started by BRADAN, May 12, 2010.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    We planned this detail down to the hour to keep it active, subcontractors had advance notice so the turn around was quick. We have been open for a year. All work space is not decorated, but painted in white or bright gray. It keeps workspaces from getting dirty and makes it very obvious when they do. Plus, it would be a shame to take focus off the real art parked inside!!
  2. FBI
    FBI Formula Junior
    May 27, 2008
    446
    Calgary,Ab
    Just joking about the art.:)
    I agree I like a white shop keeps it clean and fresh.
    Great work can't wait to see more updates!
    Cheers!
  3. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #28 BRADAN, May 13, 2010
    Stage 8: Tire mounting and wheel protection
    With the wheels back and coated, it was time to have the tires installed. Our hunter mounting machine does not have any contact with the wheels edging. This allows us to consistently mount tires without the risk of damage. Once mounted, the tires were filled with nitrogen. We prefer this gas in performance applications for a consistent tire pressure. Once filled, the tires were road forced balanced. The high quality of OEM wheels is evident in the balancing process. Only minor correction was needed.
    A mixture of 50/50 alcohol and water was applied to a microfiber towel to remove any dust and overspray. Once cleaned and dried, Autoglyms' radiant wax was applied to seal and protect the surface. This is a great process for all rims. It makes brake dust easy to clean up. Finally, tires were treated with Malco prizm dressing. We recommend this dressing even to enthusiasts. It leaves a natural lasting finish compared to the greasy wet look most products leave.
  4. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    The attention to detail is unreal.
    Looking forward to the interior detailing.
  5. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #30 BRADAN, May 13, 2010
  6. S Brake
    S Brake F1 World Champ
    Aug 3, 2006
    17,182
    Utah
    Dave
    Just subscribed to the thread, amazing work!
  7. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    I'm lovin' it!
  8. Todd Helme
    Todd Helme Formula Junior
    Apr 2, 2007
    947
    Oviedo Florida
    Todd Helme
    Wow this thread is a treat! Very nice work, the attention to the detail es bella!
  9. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    That is a lucky 355 .... can't wait to see the interior work !
  10. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Great work on those wheels.
  11. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #36 BRADAN, May 14, 2010
    Stage 9: 2000 grit body wet sand
    The actual paint correction process started today after all the prep work over the past two days was completed. Two 5 gallon buckets are filled 3/4 full of pure water. One bucket is a rinse bucket, the other is a fresh water supply. 3m 2000 grit paper is wrapped around a rubber sanding block. With florescent lighting all around and halogens as a spotter, the body is sanded 4" x 4" at a time. It is important to keep checking paint depth with a paint meter to make sure equal pressure is consistently being applied.
  12. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  13. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Great to see a world class detailer on F-chat, glad your enjoying.
  14. jmiff348
    jmiff348 Formula 3
    2,369
    Texas, USA
    Jarrett
    Those wheels give me goose bumps. :)
    Nice work all around. Can't wait to see the completed project.
  15. JOEV
    JOEV F1 Rookie
    Aug 6, 2003
    2,827
    Ontario, Canada
    Joe
    Are the shields actually stamped into the fenders or are they just stickers? We've seen a couple of 355s with stamped shields but I think they're usually stickers (?).
    Considering the amount of work and attention to detail that is going into this car, I would be tempted to lose the shields if they're just stickers.
    Just my $0.02 and no offense intended to the owner.
  16. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    man, I'd love to have the "process" done to my 355, but am afraid of the costs... that's a lot of hours.
    JD
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,690
    San Carlos, CA
    Mitchell Le
    $50/hr * 12 hrs/day = $600.
    So far, it is ... 3 days and the job is likely 25% done = $2000.
    The whole thing is ... $8,000 plus external cost of painting, and supplies, and .
    $10K easy.
    Well, that scratch there on my car can wait a little longer.
  18. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    They would have to be stickers as I believe the car is a 95.
  19. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #44 BRADAN, May 14, 2010
    Stage 11: Body 3000 grit wet sand
    With the aggressive 2,000 grit hand sanding stage complete, we moved to a finer grade - 3,000. The body was fully wiped down with a 50/50 mix of alcohol and water to remove all dust and clear the surface. 3M's trizact system in 3,000 grit was applied to a DA sander; speed was set at half speed. Using water for lubrication, each panel was sanded in stripes roughly 3' wide.
    This stage removed all scratches from 2,000 grit and fully leveled the paint. Now, there is not a single scratch or wave in the paints surface.
  20. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Time spent stripping bumpers, wheels, etc is not added to this details time. We will post actual detailing clock hours when complete.
  21. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Very impressive
  22. jmiff348
    jmiff348 Formula 3
    2,369
    Texas, USA
    Jarrett
    Plus the interior, and assuming there is only 1 technician doing the exterior work... Still probably a lot less money that a bare-metal refinish. :)
  23. jmiff348
    jmiff348 Formula 3
    2,369
    Texas, USA
    Jarrett
    I'm curious to know how much paint is removed during the wet sanding process (as a percentage).
  24. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  25. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    We are staying late tonight, updates will continue until 8 or 9pm. The following stages are the most rewarding.
