Bradan F355 valve cover repaint | FerrariChat
Discussion in 'Bradan' started by BRADAN, Mar 14, 2014.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    #1 BRADAN, Mar 14, 2014
  2. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #2 BRADAN, Mar 14, 2014
  3. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #3 BRADAN, Mar 14, 2014
  4. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #4 BRADAN, Mar 14, 2014
  5. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #5 BRADAN, Mar 14, 2014
  6. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    Hi Dan,
    I have a chip in the paint between my intakes. No need for a refinish but I was wondering what paint you use. Is it standard Rosso Corsa? I just want to be able to dab it on with a touch up brush.
  7. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Steve,
    VHT wrinkle red paint on a q tip. Put 3 coats on lightly and hit it with a heat gun. Keep in mind engine temps alter the color of the red paint so it will not match perfect. The issue is Ferrari never uses a primer just paint on metal so it eventually flakes off.
  8. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    Great thanks! Yep. Def can tell no primer underneath. Kind of ridiculous considering how expensive these cars are.
  9. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Do you have to remove the old paint? If your valve covers look good but a little dirty can you just clean with a solvent then spray a fresh coat of the wrinkle paint over the top? Also, do you wipe the raised parts after painting or just sand later? Thanks.
  10. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    The paint comes off with next to no effort. I recommend always taking it down to metal and starting with a clean slate. With something like a valve cover you will end up flaking the paint off just trying to clean it up. We machine it after to get the brushed metal look.
  11. dailyferraridriver
    dailyferraridriver Formula 3
    Nov 12, 2010
    1,402
    New Jersey
    Erik
    I think this one of the best things you can do to your car with such a huge impact. Nothing makes the engine look old/worn than flaking paint in the engine bay.
    Excellent job!
    Erik
