More gearbox assembly work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Assembled gearbox. Rear cover is left loose until installed on car. Image Unavailable, Please Login Image Unavailable, Please Login
Flywheel machined and balanced with clutch assembly. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Installing clutch assembly on the car. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fitting the gearbox. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Installing timing belt covers. They were repainted and hardware plated. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Rebuilt A/C compressor. The clutch was rebuilt and all seal replaced to run R134 gas. Image Unavailable, Please Login Image Unavailable, Please Login
Sorting out yellow cad hardware. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Assembling refinished clip latches. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Installing oil lines, sway bar, sway bar brackets. Image Unavailable, Please Login Image Unavailable, Please Login
Silver cad plated turbo mounts installed. Image Unavailable, Please Login Image Unavailable, Please Login
Subframe bars refinished in satin black powder coating. Image Unavailable, Please Login Image Unavailable, Please Login
Coolant pipes plated in clear cad reinstalled. Image Unavailable, Please Login Image Unavailable, Please Login
Sway bar end links plated in yellow Cadmium with new bearings/boots installed. Image Unavailable, Please Login
Latch assembly. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Assembled latches. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
