Braille Battery for F430 | FerrariChat
Discussion in '360/430' started by DCF430, Sep 22, 2008.
  1. DCF430
    DCF430 Rookie
    May 2, 2006
    24
    Orlando FL
    Did a search on batteries. Found the thread on the 360 replacement.
    Gonna price one in Pep Boys, AutoZone and Sears first, but will probably opt for the Braille.
    Does anyone know which Braille model and kit fit the F430? Can't believe they don't have a fit chart on their site.
  2. themash
    themash Rookie
    Jun 24, 2006
    35
    +1
    Any info on which Braille battery would fit the 430 ? Has anyone installed one ?
  3. tazandjan
    39,167
    #3 tazandjan, Sep 18, 2010
  4. themash
    themash Rookie
    Jun 24, 2006
    35
    Thanks for the info Taz.
    I was actually looking to install a light weight battery (my fault for not being clear), and was interested in the "No-weight" groupe of batteries made by Braille ( 21 lbs or 18.5 lbs )
    Anyone try these smaller batteries ? install tips ? did the Braille battery mounts work ? which mount ?
    Thanks in advance
  5. tazandjan
    39,167
    #5 tazandjan, Sep 18, 2010
    Sure you want to do that? Maximum CCA on any of those batteries is 550 amps, well below what the normal Brailles and Interstates are pumping out. See the battery document for exact specs. Personally I am more worried about starting than 20 lbs of battery weight for a street car. The MTP-91 has 700 CCA and the minimum for the Brailles in a size that will fit is 850 CCA.
    Taz
    Terry Phillips
  6. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    I tried one of those in my Gallardo, the results after 30 days I was back to a full size battery, it would not start the car it it sat more than three days.
  7. themash
    themash Rookie
    Jun 24, 2006
    35
    Many members on here are replacing their stock batteries with the Odyssey 925.
    The 18lb Braille battery has a higher CCA rating, and every other rating as well... so should be better, and 6 lbs lighter.
    Braille B2618 Odyssey 925
    Weight 18.5 lbs 24.5 lbs
    PCA 5 sec 1164 925
    CCA 472 380
    Even the lighter 15 lb Braille battery out performs the Odyssey 925..
    Not sure if i am looking at this wrong or what... but seems to me like the Braille is the way to go in terms of performance and weight.
    Any inputs ?
  8. themash
    themash Rookie
    Jun 24, 2006
    35
    Which Braille did you use ?
    The Gallardo is a V10 as well, so you need a bigger battery :)
  9. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    Use a same weight battery to keep proper balance,430 have a very good weight balance.
    No need to go light in the battery since it is placed in the right side of the car.
  10. tazandjan
    39,167
    Mash- CCA (cold cranking amps, 0 deg F) is the commonly used performance criteria for batteries. 472 CCA is pitifully low when Interstate conventional batteries and Braille and Odyssey AGM batteries are pumping out 700- 880 CCA. The original FIAMM VR 760 with which your car was fitted put out 760 CCA. Why handicap your car with an undesized battery?
    Taz
    Terry Phillips
  11. reuland
    reuland Karting
    Jan 15, 2010
    95
    tyler,texas
    kurt
    If you'retrying to save weight look into a lithium ion battery! It is an option on Porsches!
  12. themash
    themash Rookie
    Jun 24, 2006
    35
    Thanks for the reply guys..
    I am planning on installing the Titanium Tubi exhaust + carbon fiber rear diffuser, this should reduce rear weight by atleast ( 40 lbs) , so i figure the balance should be almost the same if i remove (27 lbs) from the front with the lighter battery.
    I understand the CCA is lower than the stock battery, but the Braille is still better then the very commenly used Odyssey 925 battery used by many forum members.
    Anyone have a lithium ion battery installed ? pics ?
  13. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    Yes remove weight from the rear not only one side.
  14. MrLithium
    MrLithium Rookie
    Sep 24, 2010
    1
    #14 MrLithium, Sep 24, 2010
    Hello
    I'd like to jump in here..just joined as silver
    many performance sports car owners dont know what aftermarket battery to use.
    3 things are important, weight, size, and of course; must start the car !
    Instead of guessing on battery specs.. Get a clamp-on ammeter and READ what cranking amps the starter is using. put around one of the battery cables and have a friend ( gf ! ) start the car. THEN you'll know what CCA you ACTUALLY need.
    Of course Lithium outperforms lead. Who wants to push around a 30 - 50 lb boat anchor !?
  15. themash
    themash Rookie
    Jun 24, 2006
    35
    Can someone please try this and measure the CCA of a F430 or scuderia ?? and post results.
  16. tazandjan
    39,167
    This is a joke, right? Where is someone willing to do this test at 0 deg F and how do you get the car to that temp? Just buy a battery. If you want an underpowered lightweight, buy one and let us know how it works. You can go on a diet and take out the kits in the trunk and have more affect than a lightweight battery. Unless you are Trev and are really lightweighting. Read his thread and use the battery he used. At least you will know it works.
    Taz
    Terry Phillips
  17. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    Is there any risk of a fire with the Lithium?
    A good AGM battery will outperform a conventional flooded battery and last years without maintenance. The only difference between a Group 91 and an H6 is the overall height, 15mm taller for the H6. Interstate sells a flooded battery that they call a 48/91. The Group 48 is similar to the H6. Basically Interstate/AC Delco sell a 91 that also fits in a 48 or H6 space. It is just smaller than the maximum dimensions allowed by the taller Group 48 or H6.
    AGM is more sensitive to charging and if overcharged for long periods it can shorten the life of the battery. Just something to keep in mind as all heavy bricks of plastic and lead with two terminals are not created equal.
  18. tundraphile
    May 16, 2007
    5,083
    Missouri
    That is a standard test for the industry to make comparing between models and brands easier. Some manufacturers intentionally attempt to muddy the waters a bit with things like "pulse current" or other non-standard measures to highlight special performance advantages their particular design may feature. But the 0F test is standard and the data is usually available.
  19. tazandjan
    39,167
    TP- He is not talking about the battery. He is talking about a test of how much juice the starter pulls. The 0 deg F CCA rating for batteries is a standard measure. What Mash is not taking into account is the battery needs to be able to start the car when neither it nor the car are in tip top shape. Batteries degrade over time and cars can require extra cranking at times. Buying a battery that is way less powerful than OEM just does not make sense.
    Taz
    Terry Phillips
