Brake bias/balancer | FerrariChat
Brake bias/balancer
Discussion in '206/246' started by nerodino, Aug 23, 2009.
  1. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    #1 nerodino, Aug 23, 2009
    Does anyone know for sure if the rubbers are available for this unit? I have been harping on here about a spongy pedal and when i looked at this today and pulled the rubber cap off i found brake fluid in it which means the small rubber is leaking. Sure enough upon removal and dimantling i have foun that this rubber (small one on right side of piston in first pic) is slightly loose on the piston shaft which is letting fluid by and giving me the poor pedal.
    Ron from Superformance has told me that they have several calls a month for these but have never had their hands on a unit as a pattern.....if no one has these i might as well give this to Ron and he can send them to South Africa (i think) to have them copied/manufactured and make a lot of folk out there happy.
    Any thoughts?
    G P
    Also does anyone have an exploded diagram of this or a photo of how it exactly goes together as maybe i had something wrong???
  2. swift53
    swift53 F1 Veteran
    8,295
    E.S.
    Alberto
    Graham,
    I posted a similar query about the same issue today. Maybe we can continue in that section?
    Regards, Alberto
  3. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Alberto, Dinoparts DE has them.
  4. swift53
    swift53 F1 Veteran
    8,295
    E.S.
    Alberto
    Graham, you are right. They will rebuild the unit for less than 90 euro.
    Well worth it. Thank you.
    Regards, Alberto
