430 - Brake Bleed with Launch | FerrariChat
430 Brake Bleed with Launch
Discussion in '360/430' started by fstbiker, Mar 9, 2024.
  1. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    509
    New Jersey
    Anyone ever use the Launch to bleed brakes? I usually use the Motive to do my brakes. Was wondering how it would work if I used the Motive to push the fluid from the reservoir with the Launch bleed procedure? I watch a video with the Leonardo computer and the computer said to bleed the RR. RL, LF, RF and then RR wheel again.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,931
    Isle of man- uk
    Yes it will do it, buy one of those bleed bottles with the non return valve as makes it real easy
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,739
    Central NJ
    Dominick
    I don't think you need the motive at all if you use the launch ..it uses the anti lock brake pump
  4. fstbiker
    Jun 28, 2012
    509
    New Jersey
    The video I watched with the Leonardo system show him use one of those harbor freight gravity feeds from the reservoir and an air compressor pump at the valve that pulled the fluid to the valve. I guess i wanted to do kinda the reverse with the motive. Push at the reservoir, and drain at the valve. I think its the same thing? The Leonardo said to push with the pedal during its instruction, but he did different. Also wondering why they wanted you to rebleed the right rear at the end?
  5. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,392
    Santa Clarita, CA
    I just did a brake flush/bleed with my Motive. I have a Launch but didn’t try them both at the same time. I also watched that YouTube video and wondered if it would work.
    If you try it, please let us all know how it goes. Especially the part that flash32 is talking about, that the Motive might not be needed as the cars pump will push the fluid through the system.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,739
    Central NJ
    Dominick
    Let's also consider flush vs bleed
    Flush is what 99 percent of us do to remove old fluid and replace with new
    Bleeding ..trying to remove air as well as flush fluid
    The motive alone will do a great job of flushing system and also taking care of air in the lines ..which is.99.9 percent of what we need
    When you dismantle or introduce air into the system
    . sometimes the motive by itself is not enough ..trapped air in master cylinder or in abs unit
    The Ferrari procedure as I assume the Leo specified...is to remove that trapped air
    The abs pump will move the fluid and the pumping makes sure no air in the master cylinder
    If you want to just flush you can use the launch without the pumping
    But honestly the motive is easier and pushing pressure vs pulling does a better job .. and like I said when flushing all that matters is get old fluid out especially near the calipers when the heat degrades the fluid
    mwstewart, Flyingbrick242 and Sj_engr like this.
  7. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,962
    PNW
    SKIM
    I have to agree...motive is easier.
  8. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,392
    Santa Clarita, CA
    I was also concerned about the old fluid trapped in the ABS valves.
    It’s definitely a concern, my Harley has to go to the dealer ( or I have to buy one ), every two years and they use their own version of a Launch to flush the ABS valves on their newer bikes. There’s a YouTube video showing the procedure.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,739
    Central NJ
    Dominick
    One thing that I am not sure if the launch does operate the abs valves ( we know it operates the pump) to allow fluid to flow .. or is does the brake pedal activate the valves -
  10. Flyingbrick242
    Flyingbrick242 Formula Junior
    663
    Northern AZ.
    If the launch SW is similar to OEM it should activate brake circuits exp: R/F, R/R, L/F, L/R which is flushing and bleeding internal of the ABS hydraulic circuit.
    Not often needed when servicing the brake fluid unless someone detects unusual ABS performance.
    For the record I use the Motive which works just fine.
    flash32 likes this.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,739
    Central NJ
    Dominick
    I assume as well but since I never used the launch on a f430 ( did on other cars) didn't want to promise something without first hand experience - i have to keep my trust :)
    Flyingbrick242 likes this.
