Ciao Tutti, Just wondering what is the correct sequence order for bleeding the brakes for a 3500GT ?? Molto Grazie Saluti Carlo
I start with the right rear then the left rear, then the right front and last the left front. The problem with the early cars that have the drum rear brakes is the brake bleeder screw is usually on the bottom of the cylinder. As a result air can get trapped in the cylinder. Sometimes it is necessary to remover the rear cylinder and turn the bleeder up for bleeding to get all the air out. And I only use Castrol LMA for Girling brakes
