brake caliper colour | FerrariChat
Discussion in '206/246' started by pk246gt, Oct 12, 2011.
  1. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    I've asked the Fchat members for advice on this before but want to be sure before proceeding with the caliper replating so can anyone with an E series around August 1971 (mine - 02424) let me know what colour the original calipers were from the factory ie gold or silver.
    Thanks guys.
  2. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    Paul,
    I am assuming that your calipers, like the ones on my car, are ATE. If so they are yellow zinc (often referred to as gold zinc) plated. Not gold Cadmium plated which is a different process.
    If you are particular about their appearance tell your plating shop to perform a post plate 'leach back'. Essentially what this does is tone down the strong iridescence often evident in gold zinc plating and gives it more of a straw yellow colour. If you've ever seen a new ATE caliper this is precisely how they look.
    Best Regards,
    Paul
  3. Pooh-Baugh
    Pooh-Baugh Formula Junior
    Sep 3, 2011
    488
    Greencastle Indiana
    Bob
    I went to the garage to look at mine. I have the passenger wheel off from my engine serial number search so I can see the caliper. Should I be looking for "ATE" in the caliper casting?
    btw, mine are "dirt" colored : )
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,643
    Toronto / SoCal
    Rob C.
  5. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    I assume you are rebuilding them before plating. Careful upon the rebuilding process they are not easily done but there are lots of good leads and advice on this sight
    clay
  6. BB512 1980
    BB512 1980 Formula 3
    1,263
    AIX-EN-PROVENCE - F
    Pascal
    And how were Girlings pls ??
  7. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    same colour
  8. swift53
    swift53 F1 Veteran
    8,371
    E.S.
    Alberto
    My Girlings, had not ever been rebuilt on #01104 and were silver, now they are rebuilt and are silver. :)
    Regards, Alberto
  9. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    I always thought they are original a very bright yellow/gold, but maybe you are right
    I will have a closer look when I depart the Girlings of #00306, but that will need some time..
  10. Scuderia Dino Torino
    Feb 1, 2011
    23
    Not too sure about that Matthias, all original Girling that I have seen ( also on Fiat Dinos 2.0, they are the same as 206 & 246L) were plated silver. Best, Emanuele
  11. rosso corsa motorsport
    rosso corsa motorsport Formula Junior
    Nov 30, 2008
    268
    #11 rosso corsa motorsport, Oct 13, 2011
  12. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,643
    Toronto / SoCal
    Rob C.
    It is interesting that the caliper halfs are held together with FIAT bolts. I would have thought that the bolts were supplied by Girling.
  13. swift53
    swift53 F1 Veteran
    8,371
    E.S.
    Alberto
    Actually they were "Ghirlinghini" with FIAT bolts.
    Mine are also FIAT bolts.
    Regards, Alberto
  14. Gleggy
    Gleggy Formula 3
    Sep 22, 2004
    1,595
    Land of Oz
    Gleggy
    I have just finished a set of ATE's. Like anything, the prep work is the key. So before plating I have found that if you bead/sand blast to get into the pores of the casting, then wire buff all over gives the best results. You may have to repeat the process a couple of times to get a uniform surface and texture so you don't have any scale or rust in the piston pocket. One other tip when they go into the plating tank it is important that they hang the halves so they don't get air trapped in the pockets etc. I have found that it's best if you can remove as much of the old plating as possible to get back to parent metal to get the best results. It also helps if your plating guy has experience in cast materials.
    The wire buff (steel then brass) on the spacers will remove the old plating; sometimes it will be flaking off! But you have to be very thorough.
    The 'O' ring seals for the spacers are a Porshe part # 90135192810.
    Hope this helps,
    Cheers
  15. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    thanks for clarification
    regards Matthias
  16. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I have a photo on the day of delivery of S/N00962 showing the calipers are silver. They still are.
    Andrew
  17. Scuderia Dino Torino
    Feb 1, 2011
    23
    #17 Scuderia Dino Torino, Oct 15, 2011
  18. 430 scuderia
    430 scuderia Guest
    Jun 10, 2008
    813
    I think silver would be great. ;-)
  19. BB512 1980
    1,263
    AIX-EN-PROVENCE - F
    Pascal
    #19 BB512 1980, Oct 18, 2011
  20. Julio Batista
    Julio Batista Formula 3
    Dec 22, 2005
    2,397
    Sad indeed. And ugly.
  21. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    Big thanks to all you guys, particulary Rob C. (thanks for the site).
    Your commentary clarified the issue for me.
    Will post a few images when the callipers are back.
    Paul.
  22. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    I have a color cutaway drawing of a Ferrari Dino 206 GT and the calipers are gold (yellow cad). That being said, I too had looked at unrestored calipers on an "L" series Dino and they were silver cad which led me to go that direction when I restored my car.
    It would be good to know if anyone has seen an example of a 206GT with unrestored, yellow cad plated calipers just to add to the confusion.
    Cheers,
    Keith
  23. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    Hello Keith,
    I did see the same cutaway and was confused too, but silver cad seems to be the correct colour... I checked old pictures pre restoration of #00306, #00334 and #01100, all silver.
    Regards Matthias
  24. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    I plan to service my '72 GT tomorrow and will clean and look closely at the calipers, which probably have never been restored. They will probably have turned cast-iron grey.
    Andres
  25. abstamaria
    Feb 11, 2006
    2,668
    Andres
    #25 abstamaria, Oct 29, 2011
    Here's one caliper on my 1972 GT, taken when I serviced the car this morning. It looked grey to me, initially, but there is a very slight gold tinge to it, somewhat evident in this photo.
    Andres
