brake caliper colour | Page 2 | FerrariChat
Discussion in '206/246' started by pk246gt, Oct 12, 2011.
  1. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,674
    Toronto / SoCal
    Rob C.
    No doubt that what you see is yellow zinc. It is notable that the plating is a sacraficial coating that deteriorates with time while protecting the metal underneath. Unless you protect the plating with a coating of oil it will change colour over time. That said I do not reccomend oiling your calipers ;)
  2. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,504
    Germany
    Matthias
    yes yellow zinc for the ATE is perfectly original
    regards Matthias
  3. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    Last minute hiccup: the platers want tyo get this right for me and they've asked me to ask the Fchatters how exactly others are doing the 'leach back', say, as noted by Rosemyer below, Nuvolari etc. Thanks, Paul.
  4. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    Paul,
    In order to achieve the gold colour, plating is basically done in 2 steps. First zinc is applied, followed by a very thin yellow chromate conversion coating which gives an extra layer of protection to the zinc and accounts for the yellow/iridescent colour.
    The leach is an additional extra step done after the chromate is applied. As the term suggests, this process leaches away some of the coolour in the conversion coating. I can't tell you the precise chemistry involved but I do know that this is a pretty basic operation for any well equipped plating shop and the explanation above should suffice for them to know what you are after.
    A few things. I recall my shop telling me that the leach time was short, around 30sec. as I recall. The idea is to just tone down the colour, not eliminate it completely. The second thing is that if your shop is not familiar/comfortable with the procedure the colour will wash out on its own in a short time, particularly on the calipers which see large temperature swings.
    Best Regards,
    Paul
  5. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    Thanks Paul.
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #31 synchro, Jan 2, 2014
    It is more of a lighter color than heavy yellow zinc, almost straw like coloring
    Ian (isuk) has captured the correct plating color for the brake calipers during restoration of Dino 03050 and I'm lifting his photos as examples.
  7. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,348
    Iain
    #32 isuk, Jan 2, 2014
  8. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,105
    thought the metal plate between the two halves should be black oxide?
    ed
  9. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,674
    Toronto / SoCal
    Rob C.
    I have only ever seen them zinc and I have seen a LOT of calipers.
    Another interesting to note is the position of the hand brake assembly on the cars in the photos. These are E series cars that seem to have the spring and lever assembly on top whereas the earlier M series cars have it on the bottom (as confirmed with reference cars and the parts book).
  10. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,348
    Iain
    #35 isuk, Jan 2, 2014
