Brake caliper re-build and re-plate ?'s 308 | FerrariChat
Discussion in 'Technical Q&A' started by Nuvolari, Mar 9, 2004.
  1. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,677
    Toronto / SoCal
    Rob C.
    Hi All,
    The plating on my calipers is pretty tired so I want to re-plate them. I assume this involves disassembling the entire caliper and having it re-plated before installing a re-build kit. What should I look out for in this procedure? What is involved in the re-build and what considerations should I have if the caliper has fresh plating in the cylinder bores etc. ? Any guidance would be greatly appreciated.
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,677
    Toronto / SoCal
    Rob C.
  3. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    The rebuild is quite simple. Sorry I can't help on the plating question.
  4. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,539
    Canada
    Newman
    Why dont you just ask Rocco? You know he does it and just had his all done. He can point you in the right dirrection.
  5. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    On the plating: I think Steve Magnussen has done this. You could also call Giovanni at AutoSprint in Chicago (advertises in Forza).
    Ask what thickness of coating they had done/would recommend.
    FYI, the common wisdom tends to be not to split the calipers for fear of not sealing them again easily. I did split mine (to paint them - waste of time as it happened). To re-seal, you need to buy the little seals between the caliper halves and the spacers. They are not included in the rebuild kits. Giovanni can help you (he obtained mine, IIRC).
    HTH
    Philip
  6. Steve Magnusson
    26,972
    No -- it's not me with the caliper replating experience (I was thinking maybe Ric Rainbolt had posted something on the old site -- but maybe not 308 -- I couldn't find it easily -- and it's not my homework!). My recollection is my ex-308 calipers were bare -- but I'm definitely foggy on that one. I also recall some of the 308 suspension rebuild posts including nice brake caliper restoration work too.
    Rob C. -- I do think you should do some homework and go to the old site and do a search/reading on:
    308 brake caliper ("and" mode, parts of words)
    (I apologize if you've already done that, but my take from just sampling the threads that came up from that search was that there's such a wealth of supplier information, assembly tips, etc. that you'd have phrased your original post question differently if you had already done that.)
  7. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I had my BB512i calipers rebuilt by Stainless Steel Brake Corp. www.ssbrakes.com
