348 - Brake/Clutch Fluid Leak Mystery Part | FerrariChat
348 Brake/Clutch Fluid Leak Mystery Part
Discussion in '348/355' started by JM280z, Jul 14, 2023.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    878
    Jake
    Hey All,
    I’m looking at parts diagrams and not finding the circled piece on the right. It inserts into that rubber grommet. This assembly doesn’t seem correct… is it? Image Unavailable, Please Login
  2. Rifledriver
    37,105
  3. JM280z
    Aug 22, 2020
    878
    Jake
    Good call!! Looks like piece broke a while ago and it was inserted incorrectly
  4. JM280z
    Aug 22, 2020
    878
    Jake
    Where did you find that parts diagram? Part #?
  5. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,232
    Serbia - Niš
    Miroljub Stojanovic
  7. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Be careful. If you have moved the car or activated clutch in that condition you may put air into the system and will need to bleed it well. You should bleed it anyway once you make repairs.
  8. JM280z
    Aug 22, 2020
    878
    Jake
  9. JM280z
    Aug 22, 2020
    878
    Jake
    #9 JM280z, Jul 15, 2023
    https://www.scuderiacarparts.com/part/13049/ferrari/184497/connector.html
    -$36
    https://www.scuderiacarparts.com/part/2700/ferrari/165032/pump-inlet-union.html
    -$3.28
    https://www.eurospares.co.uk/Parts/184497/Ferrari/New/63330
    -$108
    Lol, I’m sure I’ll go with the 165032 for $3.28 as the 184497 for $36 seems to be the same part but just on the 355. I’m not sure why eurospares is $108!
    175188 is another part number I just found for this, so 4 part numbers for one thing… weird
