Brake Failure light | FerrariChat
Brake Failure light
Discussion in '308/328' started by rcraig, Mar 29, 2008.
  1. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    1979 308 with strange problem. Brake failure warning light in tach comes on only when making very sharp left turns. Thought it might be some kind of wiring problem because was working with stereo wires under dash and when wires were stuffed in over stereo so they wouldn't dangle, the problem showed up. Took wiring bundle out and taped together and placed back above stereo and problem went away for a few hour drive and then when returning home the problem came back. Again it's only on very sharp fast or slow turns and it only switches on for a split second. Brakes appear to be working great. Any Thoughts>??
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Do we assume that you have checked the brake fluid? Also are you sure that the 2 floats in the brake bottle are floating and not half sunk. If this happened after you played with the radio then you should continue to search around to see if you have grounded the wire from the brake warning light. Last would be the brake failure switch under the front of the car. Considering that the brake fluid is full and the floats are OK then I still would check the light circuit.
  3. Steve Magnusson
    26,930
  4. Sheltonexplorer
    Oct 5, 2007
    6
    Washington
    Dan
    Check out this site... http://www.ferrarichat.com/forum/member.php?u=1897 posted by "Ferrarimechanic" on 4/25/07. Good article!!! I just went through this last weekend with my '79 308. Got under the front of the car...pried up the switch contact assembly out of the "imbalance valve" with a small screwdriver - that's what I call it!...gently scrubbed off and cleaned up the "tuning fork looking contacts", blew out any moisture in the "imbalance valve" cavity where the switch fits...there was moisture in it...hoping it wasn't brake fluid!!!...replaced the clean switch, and the light is out! Brakes feel as good as before...no problems, so I suspect moisture and gunk buildup of 30 years were causing the problems. The article was the source of my info. Good luck.
    Dan
  5. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Brake failure warning light comes on under 3 conditions.
    1) Key is in the starter position energizing the brake relay coil, grounding the low side of the light. Purely a test for the integrity of the lamp.
    2) Second is when brake fluid is low, energized by reservoir switches.
    3) When the brake balance differential pressure switch is energized indicating a difference between front/back circuits.
    The wires in question are all pink.
    I just went through this and it was my relay.
    ___________________
    308 Wiring Diagrams
    http://www.ferrarichat.com/ferrariads/showproduct.php?product=1036
  6. bjhunt1975
    bjhunt1975 Formula Junior
    Jul 22, 2006
    392
    ICT
    B.J.
    Very helpful...my 83 was doing this exact same thing just this weekend...only when hitting the accelerator though. I'll be checking the reservoir when I get home.
    -BJ
  7. ClydeM
    ClydeM F1 World Champ
    12,020
    Wayne, NJ
    Clyde E. McMurdy
    Thought I'd resurect this thread as my brake failure light comes on intermittently & not full bright and not always when I apply the brake.
    1) The master cylinder & Power assist unit was replaced 4 years ago and seems fine
    2) The fluid level is fine
    3) I've cleaned the resevoir contacts
    4) I've cleaned the differential pressure switch contacts (this cured the problem last time).
    But the light still comes on dimly.
    How do I get the sensor out of the differential? As suggested above by prying it out?
    also, where's the relay that was mentioned above?
    thanks.
    btw: "Check out this site... http://www.ferrarichat.com/forum/member.php?u=1897" points to the user's info, not a web site. somebody have the correct link?
  8. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    Just use a small screwdriver to pop out the sensor. It is simply a small piece of copper I think. Clean it well and also spray some cleaner into the hole and clean it with Q-tips. It will be pretty grimy in there.
  9. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    #9 rizzo308, Jul 21, 2009
    ok so i I've cleaned the differential pressure switch contacts the fluid level is fine , floats in m/cyl are ok.... dash light still on so i pulled the press switch out of the block contacts are clean my dash warn light still on what the ????????????
  10. ClydeM
    12,020
    Wayne, NJ
    Clyde E. McMurdy
    My differential switch contacts looked ok...but it turned out to be them. a carefully controlled brass dremel brush proved effective on the three contacts.
    Problem gone :)
  11. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Brake failure relay is the last relay on right, top row of the relay panel, sometimes marked as 'F'.
    The relay is only used to turn the failure light on briefly when the ignition key is in the start position.
    It's not used when the brake reservoir level OR hydraulic fluid pressure diff contacts engage to ground.
    Wires for that circuit are pink.
    Also available on the wiring diagram. http://www.ferrari308gtbi.com/
    A partially lit lamp indicates one of the fluid switch isn't clearing but has partial short. Removing
    the connector of each in turn will indicate and prove the culprit.
  12. ClydeM
    12,020
    Wayne, NJ
    Clyde E. McMurdy
    I changed my brake fluid & the Brake failure light wouldn't go out. I figured it was probably just the float on the cap.
    shorted the leads together & the light went out.
    Took the cap off & noticed it was kinda grimy
    so I carefully took it apart, cleaned everything, cleaned the contact spades & re-assembled. below are the pics of it apart for future reference.
    careful with this. there's a couple parts that will break right off.
    mixedgas and thorn like this.
  13. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Any photos of this switch and cleaning the contacts?
  14. dwhite
    dwhite F1 Rookie
    Hey Clyde, Did it resolve the problem?
    I had an issue with the boxer after changing the fluid last Fall and the breaks working. The brake failure light would flicker after driving a bit and I'm not even touching the brakes, and then come on. Then would go out, then would come on. Rebled system 4 times and checked the fluid level senders, proportioning valve and which did not resolve. Finally after pulling and checking the proportioning sender for a second time - tested okay - I just changed it as they are cheap and it resolved the issue. Light has never come back on and the brakes are excellent.
    Worst feeling in the world is seeing that light pop on even when you have good brakes.
    Hope yours isresolved.
  15. ClydeM
    12,020
    Wayne, NJ
    Clyde E. McMurdy
    Sorry, no. I used a fiberglass pen on the contacts. Liquid spray solvents didn't do enough.
    BTW: the "switch" is two nibs on the inside of the top and that metal washer. That's it. Gotta love the simplicity.
    Yes it did. Woo Hoo!
    A few years back I had symptoms you described. It turned out to be the contacts on the brake proportion valve near the steering rack. Pop off the spade connector, clean, reconnect & go :)
    dwhite and waymar like this.
