Brake failure warning light flickering | FerrariChat
Discussion in 'Boxers/TR/M' started by ferralc, Oct 5, 2024.
  1. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,153
    San Diego CA
    Fernando
    Hello I went for a drive today and on the way back (while going uphill) I noticed my brake warning failure warning light flickered for a moment, when I got home I checked the brake fluid and it is halfway between min and max (my clutch master cylinder has been recently replaced and the brake fluid was replaced too)
    I checked ferrari parts diagrams I don’t think there’s brake pad sensors in our cars, so my only guess is it going uphill made the reservoir sensor thought it was a bit low and I just need to top it off to the max, or is there any other situations where the brake warning light would flicker and then go away?? Thank you very much
  2. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,816
    Bologna
    No, the light switch is linked to the float on the top of the fluid reservoir. I would check for leaks on the brakes and clutch system and, if none are found, just top it up.
    ferralc likes this.
  3. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,153
    San Diego CA
    Fernando
    Thanks for your response, yes it was just a quick flickering while going uphill so that made me believe the angle driving uphill along with the brake fluid not at max level gave a false low level warning, but I wanted to rule out brake sensors or other possibilities that could trigger the light.
    I will just top it up, thanks again
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    I think the same but still wonder because the level was halfway between min. and max. and so normaly it would be ok and may not give contact
    uphill and sharp curve and very fast? then could be even half between min. and max.
  5. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,153
    San Diego CA
    Fernando
    accelerating uphill and bumpy, that’s why my first guess was a pad sensor but these cars don’t have pad sensors. Thanks
