Brake Fluid Choice | FerrariChat
Brake Fluid Choice
Discussion in '360/430' started by dksu, Nov 9, 2010.
  1. dksu
    dksu Formula Junior
    Oct 18, 2010
    460
    Hawaii
    David
    I'm installing brembo gt kit on my f430. What brake fluid should i buy? My car will never see track. Any recommendations? thanks
  2. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    Does Brembo have it owns recommended brake fluid?
  3. VividRacing
    VividRacing F1 Rookie
    Aug 23, 2005
    2,986
    Gilbert, AZ
    I would suggest motul rbf 660 or castrol SRF. Just depends on how aggressive you are going to be on the brakes.
  4. tazandjan
    39,169
    For street use where high temperatures are not an issue and water absorption is, I would recommend Castrol LMA (low moisture avidity). That is what I am currently running in my Mov'It ceramic brakes. Lower moisture avidity helps prevent corrosion forming on your pistons and clutch throw-out bearing flange from water absorbed by the brake fluid.
    Taz
    Terry Phillips
  5. andrewmr
    andrewmr Formula Junior
    Jun 7, 2005
    320
    Bucks County, PA.
    Michael
    What he says.....
    The fancier, more expensive, brake fluids that tout higher (dry) boiling points usually do so but also seem to absorb more moisture... which has it's own problems. If you are changing fluid frequently then that's not an issue.
    As Taz says, use the LMA for street use.
  6. thirteendog
    thirteendog Formula 3
    Mar 6, 2008
    1,587
    Nashville, TN
    Does a Ferrari 360/430 use Dot 3, 4, or 5 brake fluid?
  7. dksu
    dksu Formula Junior
    Oct 18, 2010
    460
    Hawaii
    David
    #7 dksu, Nov 9, 2010
    Thanks for the recommendations! Castrol GT LMA - is this something i can just buy from walmart? By the way, does living in Hawaii could fall under running high temperature category?
  8. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Living in Hawaii only counts for high temperatures to humans. The high temps Terry is talking about are those encountered by the brakes after repeated hard braking, as you would normally only get at a track event. I'm not saying it never happens in street driving, but in a place like Hawaii where it is humid almost 100% of the time, moisture absorption is more signficant for street driving than the high temp features of a more race/track oriented fluid. Avid track enthusiasts change their brake fluid before going to the track and immediately after coming home, and if they go to 2-3 track events a year or more doing this, that should be plenty of changing to keep the fluid relatively moisture-free. If you only change your fluid once a year, street fluid like LMA is probably a better choice. On a Ferrari, you should change your fluids (all of them) once a year regardless of mileage. Of course, it's your car and some people think some of the fluids don't need changing that often.
  9. dksu
    dksu Formula Junior
    Oct 18, 2010
    460
    Hawaii
    David
    Thanks for the clarification. You can tell i know nothing about cars
  10. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    BTW, why are you getting a Brembo upgrade if you don't track the car? The stock brakes are more than adequate for street driving and even some track. The only reason to go to bigger brakes is to get more heat absorption capacity, so that they don't fade as readily under repeated heavy braking like you'd get at ... the track. Big brake kits do not necessarily stop the car any faster and perhaps in lighter driving may not stop as well as stock brakes, because they take longer to warm up to optimum temp. If you feel the need for more "grab" to the brakes, most likely what you need or want is simply a different pad compound that has more initial "bite," that is, more braking torque for a given amount of pedal pressure. I suggest you figure out what pads you are currently running then go from there to try a different pad.
  11. tazandjan
    39,169
    #11 tazandjan, Nov 9, 2010
  12. dksu
    dksu Formula Junior
    Oct 18, 2010
    460
    Hawaii
    David
    #12 dksu, Nov 9, 2010
    Actually i'm doing it for purely cosmetic reasons. I know it is stupid. I have a 2010 911 turbo pdk with 6 piston calipers and it shames my f430 standing beside it with little black calipers.
  13. VividRacing
    Aug 23, 2005
    2,986
    Gilbert, AZ
    I'm excited to see the images once you get them on...
  14. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Well, that pic is convincing enough! Nice!
  15. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    1+
  16. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    #16 Ingpr, Nov 9, 2010
    I got a set of SpotTech big brake kit from vividracing. Insane big and nice. I also do it for cosmetic reasons.
    I know Rob!
    I will install it this week after I install your headers and the Capristo!
  17. tazandjan
    39,169
    #17 tazandjan, Nov 9, 2010
    David- Those look great. I think I like the white Ferrari as well as the black on the red calipers. Would not have worked on my yellow calipers, though. I was stuck with black with some red trim.
    Taz
    Terry Phillips
  18. dksu
    dksu Formula Junior
    Oct 18, 2010
    460
    Hawaii
    David
    For f430 do you use dot 3, 4, or 5? thanks
  19. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Check owners manual but it should be DOT 4. DOT 5 is not compatible with other fluids (unless you FULLY purge old fluids).
  20. tazandjan
    39,169
    Dot 5 is silicone brake fluid and is specifically not recommended in Ferraris because of compressibility issues. Its main advantage is it does not absorb water. DOT 5.1 is similar to DOT 3 and 4, but with higher dry and wet boiling points. Ferrari recommends DOT 4 in the latest cars.
    Taz
    Terry Phillips
