F8 - Brake fluid expired message | FerrariChat
F8 Brake fluid expired message
Discussion in '458 Italia/488/F8' started by mkraft3003, Jan 22, 2023.
  1. mkraft3003
    mkraft3003 Formula 3
    2,361
    Tampa, Fl
    Anyone ever received the following message? Calling dealer tomorrow as my yearly service is due in 52 days. Only 1400 miles on the car.
  2. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,810
    I've got the same message. I've got much greater mileage. So must tracked by both time and mileage
    Also there is a brake system recall which has to be performed
    mkraft3003 likes this.
  3. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    Just got this message and I’m about 45 days from service 2000 miles.
    What was it?
  4. mkraft3003
    2,361
    Tampa, Fl
    It was just the notice for service and that the brake fluid needs to be replaced under the maintenance program.
  5. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    Any rush or I can wait the 40 days till I do annual service?
  6. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,220
    Tampa FL
    Brake fluid is not mileage based. It's more time based. Basically brake fluid is hydroscopic...meaning it absorbs and retains water into it thus not working as good as a pressure fluid as it should.
    A brake fluid flush is cheap, change it once a year for normal street driving no more than 2 years. Track use due to heat in the brake system will need to be changed much more often.
  7. mkraft3003
    2,361
    Tampa, Fl
    No rush at all. It was just the computer sending the message and not a warning per se
    9650max and luvair like this.
  8. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    Got it thanks guys
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,916
    Isle of man- uk
    You can buy a little pen like detector you dip in the top of the fluid tank, will tell you if too much water moisture in the brake fluid.
    peterp likes this.
  10. Orinda
    Orinda Karting
    Aug 21, 2023
    66
    SF Bay Area
    Hello,
    I just also received this msg...I just did annual service about a month ago.on F8S..wonder if they forgot to do it? Hate to drive all the way back to dealer to do another service...
    "Service Stop Brake fluid expired Go to dealer"
    how long did the dealer say you can wait to do it?
