Hi all, I'm going to replace the brake pads on my scud this weekend with the help of a friend who owns a repair shop. I was thinking I should probably change the brake fluid as well. Anyone have any recommendations of which fluid to use? Although I primarily drive my car on the street, I am planning some track use so the fluid needs to withstand more intense conditions as well. Thanks!
Unless you want to go super high end, I like ATE brake fluid which I have used for both racing and street. Amazon.com: ATE 706202 Original TYP 200 DOT 4 Brake Fluid - 1 Liter: Automotive
Thanks, I will check that out. I was looking at the Owner's Manual for recommended fluid and capacity and it says "brake and clutch system." Anyone know what this means? What "clutch" is this referring to?
