458 - Brake fluid reservoir | FerrariChat
458 Brake fluid reservoir
Discussion in '458 Italia/488/F8' started by BlackF271181, Sep 30, 2023.
  1. BlackF271181
    BlackF271181 Karting
    Nov 17, 2022
    52
    H.K
  2. SD455TA
    SD455TA Formula Junior
    No, 3 things, 1 it could be that the cap was loose, 2, it could be the cap is bad, 3 could be overflow or bad filling from a service. Wipe it up, and watch it, did you get the recall done? I am not advocating the recall, I think it was a joke.
  3. BlackF271181
    Nov 17, 2022
    52
    H.K
    The recall was done. Will order a new cap n try. Thanks.
  4. SD455TA
    I'm sure you suspected those things, always try the most inexpensive thing first I always say. The most important thing here is that through your diligence and observation, you discovered the problem, that is the key, get it early.
  5. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,642
    AUSTRALIA
    ANGELO
    My 2 cents, normal ? However, since it has been replaced in the recall the cap is venting properly. Thats provided the cap was screwed on properly.
    Have you looked at the fluid level ?
    There is always the chance that something is wrong because if the ( Ferrari logic ) the cap didnt vent it could cause brake failure.
    So now your cap vents but there is some other underlining issue ?
    IMO get Ferrari to check it out.
  6. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,431
    Tampa FL
    You can can some weeping. I do not see a lot of fluid in your photo.
    Check the seals on the cap, soak it up, tighten the cap real good and then spray some degreaser and clean all around. Check it again after some drives where you use a lot of brake pressure.
  7. HMB-Dino
    HMB-Dino Formula 3
    2,280
    Pebble Beach, CA
    RonG
    What is the part # for the replacement cap?
  8. HMB-Dino
    HMB-Dino Formula 3
    2,280
    Pebble Beach, CA
    RonG
  9. up4speed
    up4speed F1 Rookie
    3,691
    Long Island, NY
    Chris
    It's black instead of clear
  10. BlackF271181
    Nov 17, 2022
    52
    H.K
    Is brembo dot 4 the oem brake fluid? The reservoir cap state dot 4 only, but dot 5.1 have better boiling point, is it okay to use dot 5.1?
  11. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,431
    Tampa FL
    #12 mdrums, Oct 6, 2023
    Your brake system was design for glycol based brake fluid. Your car came with Dot 4. DOT 3, 4 and DOT 5.1 are all glycol-based brake fluids. and are controlled by standards set out by the Department of Transportation (DOT). The main difference between these 3 brake fluids is their boiling points. Part of the standards that need to be met by the manufacturers of DOT fluids are the minimum dry and wet boiling points. If switching to DOT 5.1 use must fully flush your entire system including the ABS.
    If you flush you brake fluid all the time like after every track weekend then dry boil point is the number to pay attention to. If you flush your fluid every year then wet boil point is the number to pay attention to. 5.1 is NOT a better fluid. Most 5.1 fluids spec data sheets show a lower wet boil point which is not ideal unless your are flushing fluid all the time.
    In other words stay with DOT 4 fluid.
    I use Moltul RBF660 Dot 4. Car requires dot 4. Castrol SRF is another dot 4 higher wet & dry boil,point you can use, These 2 fluids work great with a great history for cars that are tracked and in race cars too.
    spider17, RoadRonin and Viperjoe like this.
  12. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    That has to be the most thorough and comprehensive answer to anything I’ve heard in my lifetime.
    mdrums likes this.
  13. BlackF271181
    Nov 17, 2022
    52
    H.K
    Thanks for the detailed information.
    mdrums likes this.
