Brake Fluid | Page 2 | FerrariChat
Brake Fluid
Discussion in '348/355' started by trestlenewport, Aug 12, 2013.
  1. tazandjan
    39,318
    George- If you go to ferraridatabase.com, you can download an F355 owners manual for your hard drive or smart phone. Workshop manuals, too.
  2. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    That is what I used.
  3. tazandjan
    39,318
  4. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
  5. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    My 1 cent worth: 1) DON'T use DOT 5 brake fluid...or DOT 3 for that matter....should be DOT 4!
    2) Don't sit around pumping the pedal with the key off. If the brake pressure pump can't run, and your reservoir is topped up, if you press the pedal a few times it will actually push the fluid out the top of the reservoir.
    3) Everybody knows this, but just a reminder: brake fluid is an excellent paint stripper, so be VERY careful with it and your grimy hands.
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Good find! So much for that trick.
  7. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    order 5L today.. will see if it actually shows up.
  8. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    5L of smurf blue liquid showed up on my doorstep today!
    Mobilized reply by David
  9. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
    Nice!
  10. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Back to the original question, I use two-year intervals on all my cars including the F. For nearly all the cars I own it is recommended to do this every 24 months, I would only do it more if I was to expect heavy use. I do not understand why one manufacturer would say 1 year and the other 2 years, for the same fluid type?
    Fluid coming out is always clean, and I cannot escape the feeling I am doing this way more often than the average garage for bread-and-butter cars ever would. Same interval and feeling for coolant and (on some of my cars) the oil. I basically never change diff or trans fluid, by the way. I do it once in the life of the car (when it is with me), and I believe that's fine (most manufacturers say it isn't even needed).
  11. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Our government at work to make us safe from blue colored brake fluid. I can sleep better already. I just wish they figured out that starting wars in far off countries is also unsafe for our health...
  12. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    I just did my DD at 84k miles. It was dark ... my guess is it breaks down the rubber lines?
    Not sure the Ferrari has been done recently so she'll get it this winter and maybe speed bleeders.
  13. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Dark fluid is indeed mostly a sign of deteriorating rubber lines or seals, and definitely a sign it was due. 84k, was that the first flush, and after how many years was this?
    Speaking of seals, I am picky about master cylinders. I once had a total brake failure without any warning, on a dual system car, which was due to an ageing master cylinder.
    Since then, I do not take chances and find reasons to overhaul or replace them for good measure - such as when the car hits 15 years (give or take a year), or a certain mileage.
  14. ClydeM
    ClydeM F1 World Champ
    12,093
    Wayne, NJ
    Clyde E. McMurdy
    somebody have a link to bleeding the 355 clutch too?
  15. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I did mine when I installed my calipers and brake lines.
    Take a ride down Clyde and well do it together. ��
  16. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
    The clutch is really easy, especially if you have a power bleeder (one of those pressurized things). The clutch uses the same reservoir, so just pressurize it with the power bleeder and then put a hose on the bleed nipple on the left side of the pumpkin. I don't think you need to even jack the car up for this one, but just look under your rear bumper on the left side of the clutch and it should be right there, if I remember correctly.
  17. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    At least 50 I bought it at 30.
