Brake light bypass ...Critical for F1 owners | FerrariChat
Discussion in '348/355' started by Skippr1999, Oct 15, 2015.
  1. Skippr1999
    Skippr1999 F1 Rookie
    4,485
    #1 Skippr1999, Oct 15, 2015
    As discussed previously, F1 cars will strand you if a brake light fails.
    Today I installed the F1 Brake Fail bypass that I bought from Stef at Scuding in Switzerland. It cost only $100 with free shipping included !! I got it in about three days amazingly from Switzerland.
    All you have to do is plug this harness between the brake light assembly and the car's harness.
    No more brake light F1 worries.
  2. Skippr1999
    4,485
    #2 Skippr1999, Oct 15, 2015
  3. Skippr1999
    4,485
    #3 Skippr1999, Oct 15, 2015
  4. Skippr1999
    4,485
    #4 Skippr1999, Oct 15, 2015
  5. Skippr1999
    4,485
    #5 Skippr1999, Oct 15, 2015
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Sounds cool.
    Have you tested it by pulling a brake light?
  7. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    424
    Carolinas
    Ken
    Anyone know how this works? Seems like the functionality could be recreated if someone wanted to homebrew it themselves.
    Thanks Skipp for reminding us F1 owners to watch out for this gremlin.
    Ken
  8. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    sorry not sure I understand why an f1 car will leave you stranded if a brake light fails?
  9. Ricambi America
    Sponsor Owner
    Also of note, if the engine hatch contact switch fails (or isn't securely closed), you can be stranded too. :(
  10. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Daniel, is this just an F1 issue, or are we who know how to shift gears affected too? ;)
  11. phrogs
    phrogs F1 Veteran
    7,321
    Michigan
    Beccause it wont fing shift. You're then stranded for a light bulb. I say carry lightbulbs just like the tool kit provides.
  12. 308 GTB
    308 GTB F1 World Champ
    11,662
    New Jersey
    Barry Wolinsky
    Another design wonder by Ferrari!
  13. mello
    mello F1 Veteran
    5,469
    CA Bay Area
    Steve
    So the bypass allows you to drive home without the brake lights. No thanks. I'll get it towed instead of taking the risk of being rear-ended. :)
    To build your own: R=E/I
    R = Ohms
    E = Volts
    I = Amps
    Most likely, a 6 ohm, 5 Watt power resistor will do the job. That's what I used when converting my 360 lights to all LEDs.
    Cost: less than $15.00 USD.
  14. Skippr1999
    4,485
    Each to there own. I'd rather drive with no brake lights than sit on the side of the road waiting for a tow !
    I posted this to help folks who aren't aware of the issue.
  15. mello
    mello F1 Veteran
    5,469
    CA Bay Area
    Steve
    A bad brake pedal switch will leave you stranded too. I suggest that you carry a spare. :)
  16. judd10
    judd10 Formula Junior
    477
    Seattle, WA
    If I have LEDs, which almost never burn out, does that mean I probably don't need to worry about this issue?
  17. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,133
    Adelaide, South Aust
    Steve
    Ummm. Not sure if I'm missing something, but are you saying that if a brake light bulb goes out you will be stranded?!
    If so, that is wrong.
    I had a brake light bulb fail last year and my car continued to perform completely normally (in fact in the drive by video I posted on you tube you can see one of my brake lights is not working!)
    I just bought a new bulb and put it in when I got home with no interruption to normal operation at all.
    If you are saying something else, ignore me and carry on!
  18. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,212
    Robb
    Thanks for the information.
    Robb
  19. phrogs
    phrogs F1 Veteran
    7,321
    Michigan
    well I can say this as I haven't tried the bulb yet. But someone had a issue with the tail light fuse. His was blown and it wouldn't shift.
    I took out my tail light fuse and it wouldn't work.
    I am not sure if losing one bulb will cause this but the fuse really will.
  20. Skippr1999
    4,485
    I haven't pulled a bulb yet, but unplugging the taillight plug rendered the F1 system inoperable.
  21. Steve355F1
    Aug 26, 2011
    17,133
    Steve
    Ok that must be the difference then because my fuse was fine.
    So really as long as you carry a spare fuse you should be ok.
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    Spare fuses and bulbs as said before are in tool kit.
    For my car the rear bonnet switch if it malfunctions can be unplugged and then it works. I think most f1 s are the same.
    More importantly the 30 amp f1 fuse which is not in your tool kit will leave you stranded.
  23. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    The 355F1 system will still work if you have a burnt bulb,It will not work if your brake light switch is not working.
  24. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    214
    Yikes! Had no idea light bulb failure, brake pedal switch failure, and engine hatch contact switch failure would render F1 inoperable. Are there any other potentially fatal dinky parts? Shame to be stranded because dinky part fails. Nothing wrecks a date faster.Has anyone perchance made a Critical Dinky Parts Kit or List? Would seem wise to have these items along with install instructions and install tools permanently in vehicle. Anything to avoid the horror of a flatbed tow.
  25. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    I think you misread Michael and I both . Only brakelight switch will leave you stranded.
