360 - Brake light flashing | FerrariChat
360 Brake light flashing
Discussion in '360/430' started by jackgt, Apr 7, 2023.
  1. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    I noticed the brake light flashing a couple of times. I thought it was the hand brake switch, but it is not that. Master cyl level OK. It just flashes irregularly sitting at a stoplight at times and pump the brake pedal it goes off. Master cyl bypassing?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Sounds like the brake light switch has a fault- hand brake is not connected to brake lights i have seen
  3. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    #3 Qavion, Apr 7, 2023
    What do you mean by the brake light? This (BRAKE) or this (PARK)?
    The (PARK) or (P) warning is only illuminated by the handbrake switch.
    The (BRAKE) or (!) warning, is illuminated by brake fluid levels (level switches can be faulty) and by front brake wear sensors (brakes may be worn). Isolate the (BRAKE) issue by disconnecting the brake fluid level sensor on the reservoir. If the light doesn't come back on intermittently. The level sensor is faulty.
  4. mb5
    mb5 Karting
    Nov 11, 2017
    132
    Los Angeles
    Matt
    I have the same issue going on currently. There’s a thread. Qavion helped me isolate it to my front right brake pad.
    I’m heading in for my annual soon, and expect that replacing my brake pads will make it go away.
    Do you know how old your brake pads are?
    Qavion likes this.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Age does not matter, remaining material does
  6. Qavion
    14,259
    Ian Riddell
    According to the Workshop Manual, the minimum thickness of the pads with the anti-noise plate is 7.5mm
    mb5 likes this.
